Fuel tank question
Old Mar 7, 2005 | 01:38 PM
Lone Ranger's Avatar
Lone Ranger
Default Fuel tank question
There has been a definite pattern since I've had the '95 where for some reason it feels slightly stronger when the fuel level is off of full, maybe from about 3/4 tank on down.
It's like once there's some more air space inside the tank, it helps somehow.
What does this sound indicative of? Some type of venting problem?
Old Mar 7, 2005 | 02:44 PM
Mo_Bandy's Avatar
Mo_Bandy
perhaps the EVAP solenoid isn't working, it is near the front on the passengerside manifold close to the throttle body.
Depending on the vent cycles etc, you should be able to hear it vent off pressure.
Hope this helps Mo
Old Mar 7, 2005 | 04:59 PM
Lone Ranger
Hope this helps Mo
Is that the Charcoal Canister Purge solenoid? How can one test for proper function?
Old Mar 8, 2005 | 02:11 AM
Mo_Bandy's Avatar
Mo_Bandy
I would think if you apply 12 volts to it you should hear it at least click...
Mo
To Fuel tank question
