Cruise Control not working
Old Mar 8, 2005 | 01:33 PM
J H's Avatar
J H
Default Cruise Control not working
The cruise control on my 85 does not work. At one point it failed to work and then later started back working. Now it is out of order seemingly for good. What do I ned to check before I begin replacing parts? I want to do some troubleshooting before I begin. Is the servo the only thing that goes bad or are there other things that I should check out first?
Old Mar 8, 2005 | 01:58 PM
bogus's Avatar
bogus
Check the vacuum lines that feed the servo... they are prone to failure.
You don't mention it, but does the climate control work ok? A broken vacuum canister can most surely cause this problem.
Old Mar 8, 2005 | 02:06 PM
JCAIRE2's Avatar
JCAIRE2
Vacuum line runs from the canister along the driver side fender in the wire harness to just behind the alternator where it "t"s off to the engine. Follow the harness along the fender to the cruis control.
Old Mar 8, 2005 | 02:17 PM
dan6712cc's Avatar
dan6712cc
Mine was a vacuum line, I cut the tear out and spliced the line with a biger tube, works like new now.
J H's Avatar
J H
I have vacuum on the line coming from the cannister. I assume that the amount of vacuumk is sufficient. However, there is a vacum line that goes to somewhere else under the car. Should there be suction there also? And, yes, the heater/AC controls seem to work as they should.
Old Mar 8, 2005 | 02:37 PM
dans86's Avatar
dans86
Check the position of your sensors down by your pedals, they might need to be repositioned.
Old Mar 8, 2005 | 02:48 PM
VAHROOM's Avatar
VAHROOM
Default There is another thing I didn't see mentioned.
Check the courtesy mirror lights on the visors. If they don't light, there is a 3 amp fuse for them and the cruise.
Old Mar 8, 2005 | 03:01 PM
J H's Avatar
J H
Yes, the 3amp fuse is OK. Also, the lights on the visor work. I checked the fuse first.
Old Mar 8, 2005 | 03:18 PM
hz900's Avatar
hz900
Could very well be the switch in the steering column. I have seen quite a few of these go out on older/higher mileage GM vehicles. The trucks seem espesially bad about it for some reason. I've got a friend that has had to replace his in a truck twice in the past 13 years he has had it.
Sorry though I forget the procedure for checking this.
Old Mar 8, 2005 | 03:26 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
If everything else seems to be OK, the vacuum switch on the brake pedal may need to be adjusted.
Old Mar 8, 2005 | 04:07 PM
J H's Avatar
J H
Thanks for all the replies. This forum is the greatest. I am going to chek out the vacuum switch near the break pedal tomorrow. The vacuum line that I did not know where it was going is the one going to the break pedal. I'll check the positioning of this tomorrow. Does this vacuum switch ever need replacing? I want to make sure that the problem is not the servo before I buy one. That thing is too expensive to buy if it is not needed. Again, thanks for all the great replies.
Old Mar 8, 2005 | 05:03 PM
SPEED750's Avatar
SPEED750
With the cruz off, turn the key on but don't start the car. Now switch the cruz on, you should hear the servo click. If not it could be the switch.
Old Mar 8, 2005 | 06:01 PM
VAHROOM's Avatar
VAHROOM
I would also put a WTB in the parts section. You may be able to buy one right from some one that took theirs of to make a race car lighter if that is the problem.
Old Mar 8, 2005 | 09:34 PM
HeeHaw89's Avatar
HeeHaw89
When mine stopped working it was the switch connected to the brake pedal that had come loose. Got it back together and it started working properly. However, it has since stopped working again and I haven't gotten under there to mess with it again
Old Mar 9, 2005 | 08:58 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I put the diagnostics here http://members.shaw.ca/agent86/Cruise%20Control.pdf
Old Mar 9, 2005 | 09:13 AM
MrRenoman's Avatar
MrRenoman
My CC went out some time back. Traced it back to the CC switch on the turn signal stock. This part is over $100 so a thorough test is necessary so you don't throw money at the car. The link that Agent86 posted looks like the hot ticket for troubleshooting the system. A vacumm leak to the servo or a leak in the line going to the brake vacumn switch will cause it not to work. Funny thing about the new switch I bought from the dealer, it was defective too right out of the box. I didn't realize this til after the warranty ended because I didn't install it til a couple of months after I bought it. What are the odds of that happening? Anyway, replaced it again and it works fine. Darn GM parts.
Art
Old Mar 9, 2005 | 10:31 AM
J H's Avatar
J H
Thanks a million for all the replies. I have checked everything out that was suggested and all seemed to work as specified. Therefore, I have ordered a servo from AutoZone. The cost was $59.99 plus the core charge of $20.00. I figure that at that price, I could take the chance at that being the problem. Eckler's wanted $299.00 for the servo. The price difference is great, but since this is not a critical engine part, I can take a chance at the much cheaper part being OK for a while. When I get it installed I'll post the results. Again, thanks for all the great replies.
To Cruise Control not working
Old Mar 9, 2005 | 12:21 PM
bogus's Avatar
bogus
good luck!!!
Now, order up your factory service manual!!! www.helminc.com
Old Mar 9, 2005 | 12:26 PM
J H's Avatar
J H
I have the Helms manual as well as the Haynes. Contrary to what many of you think, I like the Haynes better. But, that's just my feeligs. The Helms has the advantage as far as schematics, etc. are concerned, but the Haynes usually provides me with the best "how to" information.
Old Mar 9, 2005 | 12:57 PM
bogus's Avatar
bogus
I have noticed that, too.
The earlier Helm manuals are no where near the quality of the later manuals. Night and day difference.
