Tv Cable C4
Old Mar 10, 2005 | 08:44 PM
corvettejoe's Avatar
corvettejoe
7th Gear
Default Tv Cable C4
i'm in the process of changing from a 6 speed to a automatic in a 93 vette does the tv cable go to the asr box? and where? i need to find information on this issue and wiring issues also. please help. thanks
Old Mar 10, 2005 | 09:51 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
yes, the TV cable goes to the ASR box, along with the cable to the TB, the pedal, and the cruisecontrol.
Old Mar 10, 2005 | 10:12 PM
VetteTech81's Avatar
VetteTech81
Why are you swap from the 6 speed? If you dont mind my interuption..
-=Rick
Old Mar 15, 2005 | 10:14 PM
corvettejoe
7th Gear
i keep on going threw clutch. also want less spin off line
Old Mar 16, 2005 | 01:49 AM
85 500 horse's Avatar
85 500 horse
No offense, but if you keep going through clutches, either you or someone who drives your car doesn't know how to properly drive a stick. A clutch should last on average about 75,000 miles. More, if you baby it. Riding the clutch can easily wear it out well before its time.
Have you had it checked out to ensure nothing is pushing/pressing on the clutch causing premature wear? Before going through the expense and hassle of a manual/auto changeover, think about installing a Centerforce dual friction clutch. They're made to take extreme abuse and they're used alot in racing. So if you don't race, they will last that much longer.
Just a thought.
To Tv Cable C4
