Air Conditioning assistance needed
Old Mar 11, 2005 | 07:58 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Default Air Conditioning assistance needed
I discovered that the pressure valve on my AC unit ('96, LT1) was leaking (oil on it and when I removed it, there was no refrigerant pressure). I've ordered a new one, and it should be in today. Question: since the refrigerant has leaked out, do I need to pull a vacuum on the system, or is it OK to just recharge it? I don't know how long it's been leaking, but the AC worked fine last fall.
Maybe this belongs in Tech - Mojo, can you move it?
Old Mar 11, 2005 | 08:55 AM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
pull it down into a vacuum first. Then let it sit for a while to see how it holds. A micron gauge would help too.
Old Mar 11, 2005 | 12:54 PM
nitrous1's Avatar
nitrous1
St. Jude Donor '06-'07-'08-'09
Did you leave the system open to the atmosphere or did you reinstall the old valve until you get the new one? If you left it open - you should probably change out your receiver-drier as well (and replace any oil that might be inside)- the dessicate inside the drier will become saturated with moisture from the atmosphere. Either way - you will need to pul a deep vacuum on it to boil out any moisture in the system.
Good luck
Old Mar 11, 2005 | 01:41 PM
SilverBeast
St. Jude Donor '05
Nope - was not open to atmosphere, and I think the shrader valve is OK. So I'll pull a vacuum and recharge. Thanks.
Old Mar 12, 2005 | 04:42 AM
JTHVETTE's Avatar
JTHVETTE
Default airconditioner
I suggest that you replace the accumlator, orifice (type of filter), flush the system completely and then add oil per instructions. Put all the parts back in place. (You might want to assemble the parts prior to the oil and pull a vaccum to test for leaks.) Then pull (another) vaccum and start adding freon.I usually jump the low pressure switch wires out with a piece of wire to get the compressor to engage it's clutch when charging the system. I do this until the switch can cycle the clutch on and off by itself.(remove the jumper and plug up the wire every now and then.)
Old Mar 13, 2005 | 02:28 PM
jsinga's Avatar
jsinga
It might be a good idea to replace the scharder valves. They are one of the biggest causes of refridgerant loss. Get good ones for AC.
Did it have even a little pressure when you started? That might let you know if the system was contaminated.
Some of the R134a AC oils are real bad about absorbing moisture. That's why it was suggested to replace accumlator, orfice and flush system.
If it holds a vaccuum you can recharge and it will cool. If the desicant is contaminated the water will form acids and cause corrosion in the system.
There is a AC info web page, it has good info.
JS
Old Mar 14, 2005 | 11:12 AM
SilverBeast
St. Jude Donor '05
There was a little hiss when I punched the valve, so was not open to atmosphere. Took it to dealer on Saturday, shared all your comments, they checked the system out, replaced the little filter just before the evaporator, pulled vacuum, no leaks, filled with refrigerant, and again, no leaks, so is repaired for the moment. Thanks for the tips.
To Air Conditioning assistance needed
