Check engine codes on 92 LT1 MN6
Old Mar 12, 2005 | 09:32 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Default Check engine code 72 cause?
I'm getting two codes (4) H 52 and (4) H 72 on my 92 six speed so...
52 Engine oil temperature was below -31? F after engine had been running for 30 minutes.
the code 52 is probably due to my broken oil temp sending unit
I need to replace this but that's cake
72 2nd or 3rd gear switch was open for 1.5 seconds when vehicle speed was above 30 MPH with engine speed greater than 5000 RPM and a throttle angle above 70%.
and the code 72? The skip shift is deleted in my chip so ... ? I do remember screwing around with the cags plug when I was under there last week and thinking that I probably didn't need the cags disable plug anymore now that it was deleted in the chip .. what sets this code off?
do I have the correct interpretation for the code 72?
Old Mar 12, 2005 | 11:33 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Old Mar 13, 2005 | 03:09 AM
bogus's Avatar
bogus
I will check my Helm Manual in the morning... I donno about 72. that's odd.
Old Mar 13, 2005 | 11:54 AM
Nathan Plemons's Avatar
Nathan Plemons
72, never heard of that one, that's cute.
Old Mar 14, 2005 | 10:23 AM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I'll look at it this week when I'm under the car replacing the oil temp sending unit I might have unplugged the cags thing last time I was under the car but I wouldn't think it would matter oh well it can't be that serious right ?
Old Mar 14, 2005 | 05:49 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
ttt
any ideas for me on the code 72?
Old Mar 15, 2005 | 12:21 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Old Mar 15, 2005 | 08:24 PM
JCD's Avatar
JCD
Undo what you did to the CAGS...
But "throttle above 70%" is NOT a condition of the 1-4 lockout. So my guess is that it is not directly a CAGS problem. Sorry I can't be more helpful.
To Check engine codes on 92 LT1 MN6
