Temp erratic
Old Mar 13, 2005 | 11:54 AM
alanp1's Avatar
alanp1
1st Gear
Default Temp erratic
Just changed plugs and wires on my 92 LT1, also put in 160deg thermostate and a coolant temp sensor (the one screwed into the water pump). Now when I first start it up when it's cold it immediately reads 142 degrees and service engine soon lite comes on. Then temp fluctuates between 142 and any lower number and misses slightly until the temp goes over 142 then everything runs fine, service engine soon lite goes out, runs smooth and temp runs between 169 - 180. Any ideas? Thanks alanp1
Old Mar 13, 2005 | 04:36 PM
RadPolo96's Avatar
RadPolo96
I would just keep watchin it. I have had 2 of those sensors go bad on me. Good thing they are cheap.
