LT1 oil pump drive replacement
Old Mar 20, 2005 | 10:34 PM
1uke's Avatar
1uke
Default LT1 oil pump drive replacement
I need to replace the oil pump drive gear but cannot find a part # can anyone help me out with this?
Old Mar 21, 2005 | 12:30 AM
1uke's Avatar
1uke
Old Mar 21, 2005 | 12:59 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You can probably get the number from GM Parts Direct's website.
Old Mar 21, 2005 | 04:41 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The http://www.dougrippie.com/ might have it.
Old Mar 21, 2005 | 11:11 AM
tjwong's Avatar
tjwong
Call your local dealer. Most have them in stock, the guy I deal with had two in stock which I got
Old Mar 21, 2005 | 04:17 PM
1uke's Avatar
1uke
Their are 5 different gears so I'm told.
The 1st gear I purchased is .490 Ø
The gear required is .430Ø
Old Mar 21, 2005 | 06:19 PM
MaxLean's Avatar
MaxLean
I recently went through this too. There does not appear to be a correct size gear available, certainly not in the aftermarket. The only soulution that I found was to replace the entire assembly. The best price I found was around $41 from Dal Chevrolet in FL. BTW, the part # is: 1103868.
Old Mar 21, 2005 | 11:29 PM
tjwong's Avatar
tjwong
There are no aftermarket replacements for the LT1 gears. Mainly because it is some bastard size that GM decided to use. I wonder what goes through their so called engineers at GM. While they had probably millions of standard distributor gears for the standard HEI shaft size, why couldn't they have just made that drive with a standard size shaft?? Then we could go to Comp Cams, Crane or many other vendors for a replacement gear. Comp is tooling up to give is an Polymer alternative as is Crane.
To LT1 oil pump drive replacement
