Engine noises
Old Mar 21, 2005 | 11:12 AM
502z28's Avatar
502z28
1st Gear
Default Engine noises
Hello everybody,
Im a newbe here. I just found this forum and it sounds like a great one.
My father just bought his first vet at 60 years old. He bought a 91 convert in show room condition with only 30,000 original miles, from his nephew.
We picked it up in Ogden, Utah last summer. On the way home to California we stopped in Wendover and the engine was making an awful rattleing noise. (really loud) We let it sit for a couple hours and it was still there. So, we put some STP treatment in it for the heck of it and it diddint do anything. We drove it on home with the noise, the further we drove the quieter it got.
We changed the oil when we got home, and still to this day it still makes the noise every now and then. Mostly when you give it a rev and let off. (When the idle is comming down we here it)
I have read through the threads and only found it to be the pre cats or loose rockers. But with my stethescope it sounds like the middle of the engine. No noise from the rocker covers , oil pan or the pre cats.
Has anybody had this problem or have any ideas on what it could be?
Thanks in advance........... Rob
Old Mar 21, 2005 | 11:18 AM
tjwong's Avatar
tjwong
Originally Posted by 502z28
Hello everybody,
Sure sounds like the cats to me. Raise the car up and then bang on the cat to see if any rattle can be heard from the cat. If it was a mechanical problem with the engine one would think it would have came apart by now
Old Mar 21, 2005 | 11:27 AM
CFI-EFI's Avatar
CFI-EFI
You got really lucky. You let a Corvette sit, unattended, in Wendover for a couple of hours, "and it was still there.".
It is almost impossible to diagnose a noise without hearing it. It could be anything from a rod knock to loose lug nuts. The, "it sounds like the middle of the engine.", points more to a rod knock, than anything else.
RACE ON!!!
Old Mar 21, 2005 | 11:51 AM
rws.1's Avatar
rws.1
If you had not said ..."Mostly when you give it a rev and let off. (When the idle is comming down we here it)" I would have suspected timing and pre-detonation (engine knock or pinging) . Is it happening under heavy load? or only when it is returning to idle?
If it is under heavy load, I would check the tiiming and ensure you use a higher octane gasoline.
To Engine noises
