Accessing Stored Codes?
Old Mar 21, 2005 | 09:49 PM
46snake's Avatar
46snake
Default Accessing Stored Codes?
Ok here we go again, Jake told me how to access my stored codes by useing a paper clip on my computor relay but before i could print it out it was going, so what terminals do i use and what do the flashes mean, How many and how do you count them, Thanks .......
Old Mar 22, 2005 | 12:37 AM
bogus's Avatar
bogus
The flashes are counting like this:
<flash> pause <flash> <flash> longer pause
then the code.
A code 43 would look like this:
<flash><flash><flash><flash> pause <flash><flash> <flash> longer pause
Five times.
If there is another code, then you will get that. if not, a 12, again. And the cycle repeats itself.
The 12 indicates the ECM is active and working.
Old Mar 22, 2005 | 12:45 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Jumper pins A & B (upper two) of the ALDL, turn the key On and count the flashes and jot down the numbers till you see the 2nd set of 12s.
Note that each code will be two digits like 22, 32, etc.
Old Mar 22, 2005 | 02:14 AM
PierEagle's Avatar
PierEagle
ALDL terminals are: F E D C B A
...........................G...........M
Ground A & B. With key on, 12 will flash 3 times, then each trouble code stored will flash 3 times each. After all stored trouble codes are shown, 12 will flash 3 times again. Before any repair is made, disconnect battery. This also serves to clear any stored codes.
Old Mar 22, 2005 | 06:07 AM
Steel Blue 91's Avatar
Steel Blue 91
Here's a shot of your ALDL:
Jump A and B and count the flashes like bogus stated. To be on the safe side, make sure the ignition is off when you jump the terminals then rotate to the on position (don't start). Turn ignition off before you remove the the jumper.
Old Mar 28, 2005 | 07:19 PM
shottel's Avatar
shottel
i have a 95 (OBD1 with OBDII connector). What pins do i jump to read the codes?
Old Mar 28, 2005 | 10:22 PM
Sam Lam's Avatar
Sam Lam
"Ok here we go again, Jake told me how to access my stored codes by useing a paper clip on my computor relay but before i could print it out it was going, so what terminals do i use and what do the flashes mean, How many and how do you count them, Thanks ......."
Hey Snake: Go to Auto Zone and ask for the FREE metal key that goes into the ALDL connector and use the paper clip to hold paper sheets together! The key is free and easy to use!
SAM
Old Mar 29, 2005 | 01:43 PM
Steel Blue 91
Not sure on this one. Perhaps someone else can chime in......
Old Mar 29, 2005 | 04:13 PM
Lone Ranger's Avatar
Lone Ranger
#4 and #12, as follows, if your 95 has the 16 pin OBD2 type ALDL:
To Accessing Stored Codes?
