I have had many corvettes but this is a first.I have a 1990 6speed.
The problem is when I start the car or shut it off the headlight motors run. This is my second c4 and I dont remember my 96 doing that. I tried reading up on it but I cant get any answeres. Hopefully you fine gals and gentleman can help me out with this problem. Happy EASTER.
What do you mean the headlight motors run?
Do the headlight buckets open when you turn the ignition on and then the buckets go down when you turn the key off?
Is it possible you have a Canadian export car which has the Daytime running lights?
