Alternator Install
Old Mar 25, 2005 | 03:15 PM
auger58's Avatar
auger58
Default Alternator Install
My alternator just went on my 90 & need to put in a new one.Any advice or a thread on how to do it. I hear it's a pain in the butt.
Old Mar 25, 2005 | 03:25 PM
JCAIRE2's Avatar
JCAIRE2
Should take about 5minutes. Remove serpenting belt. Unbolt alternator wire, unbolt alternator from brace. Bolt alternator to brace and replace wire, done.
Old Mar 25, 2005 | 03:27 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Also make sure you disconnect the battery.
Otherwise you may end up doing some arc welding.
Old Mar 25, 2005 | 03:28 PM
JAKE's Avatar
JAKE
Don't know about the 90, but I changed mine (86) in about 20 minutes on the side of the highway in the darkness with only a flashlight to see by.
Mine only has a fews bolts/nuts that need to be loosened or removed.
From memory, disconnect battery POS terminal
1/2" ratchet to take tension off serpentine belt, then remove belt from alternator pulley.
Top brace: loosen inner bolt and remove outer bolt; rotate brace upward enough to clear alt.
Lower brace to exhaust: Remove nut on exhaust and remove bolt on alternator, set brace aside
Bottom most bolt: Remove
Disconnect electrical wires.
Alternator then slips right out.
Installation is the reverse.
Bing, Bang, Done.
Jake
Old Mar 25, 2005 | 04:42 PM
auger58's Avatar
auger58
Default Thanks
I'm going to do it now
To Alternator Install
