Speedo Gear Correction ?'s
Old Mar 27, 2005 | 03:36 PM
Carolina C4 Racer's Avatar
Carolina C4 Racer
Default Speedo Gear Correction ?'s
Is it possible to correct the speedometer on a 92 if I run a rear gear ratio that is lower than 3.73 (i.e. 3.92 or 4.09)
The car currently has the stock 3.54 gears & dana 44.
Anthony
Old Mar 27, 2005 | 04:12 PM
CFI-EFI's Avatar
CFI-EFI
Yes. Just change the driven gear for one with a proper tooth count.
RACE ON!!!
Old Mar 27, 2005 | 05:03 PM
Carolina C4 Racer
RACE ON!!!
Can you provide me with more info?
Where can I buy these drive gears?
App. cost ?
Thanks for your help,
Anthony
Old Mar 27, 2005 | 05:36 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
This has all the factory gears, but if you know the tooth count, you can rprobably find the one you need.
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
Old Mar 27, 2005 | 06:13 PM
CFI-EFI's Avatar
CFI-EFI
App. cost ?
Anthony
Any Chevy dealer. *I* haven't bought any, but I understand they are "reasonable", like $20.00 or less?
RACE ON!!!
Old Mar 27, 2005 | 06:58 PM
jerkyboy's Avatar
jerkyboy
I may be mistaken, but I believe that to go lower than 3.73, you must get a new "drive" gear as well. It's located on the tailshaft. This operation is quite a PITA. I put 4.11s in mine and had to do this. The other alternative is to purchase a Dakota (sp?) black box to trick the ECM to read the right speed. I'd do that if I could do it over again. Just my $.02
BTW, call Exotic Muscle..they put together a drive and driven gear combo set up for a 4.09 (was close enough for my 4.11)
Old Mar 27, 2005 | 07:37 PM
CFI-EFI's Avatar
CFI-EFI
Coming from 3.54's the drive gear won't have to change. Neither will the VSS. That's why I responded,
RACE ON!!!
To Speedo Gear Correction ?'s
