Descreening the MAF
Old Apr 9, 2005 | 07:56 PM
Impala Balko's Avatar
Impala Balko
Default Descreening the MAF
If i remove the mesh screen in 94 vette will this affect performance in a positive way or will it possibly cause my MAF to break
Old Apr 9, 2005 | 08:21 PM
Hotred94's Avatar
Hotred94
I removed the back screen but left the front screen in; I've seen some fairly sizable stuff slip through the air filter.
Old Apr 9, 2005 | 08:38 PM
Lone Ranger's Avatar
Lone Ranger
Screen removal helps L98's, doesn't help LT1's or LT4's.
Old Apr 9, 2005 | 08:52 PM
vader86's Avatar
vader86
Doesnt help LT1.
Old Apr 10, 2005 | 12:15 PM
larryfs's Avatar
larryfs
they're not screens. they're air straightening fins.
Old Apr 10, 2005 | 02:34 PM
tjwong's Avatar
tjwong
My recommendation is to NOT MESS with them. If you do, you take the chance of changing the calibration of the sensor itself. And if that happens the calibration will no longer match the calibration tables within the PCM. That means that the PCM will see either less or greater than actual airflow which will cause the fuel trims to skew to one side or the other. In extreme cases the PCM can be skewed to a point where it can no longer control the fueling of the engine.
Old Apr 10, 2005 | 03:13 PM
larryfs's Avatar
larryfs
EXACTLY. the fins straighten the air so it can be measured properly.
Old Apr 10, 2005 | 06:20 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If it's for straightening across the maf, what's the rear screen for?
I removed my rear screen.
Old Apr 10, 2005 | 10:00 PM
Lone Ranger
LT1's only have front screens. L98's have front and rear.
Old Apr 10, 2005 | 10:04 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
What about a forced induction setup? De screen or not?
Old Apr 10, 2005 | 10:10 PM
rws.1's Avatar
rws.1
Descreened mine, but left the fins in place a year ago... no negative issues, but I can't say that it gave me any increase in performance.
Old Apr 10, 2005 | 10:11 PM
CentralCoaster
There ya go. Sounds like GM figured out the rear screen served no purpose.
Old Apr 11, 2005 | 12:48 PM
mffi115's Avatar
mffi115
Default How to replace screen.
I removed mine on my LT1. I damaged the screen and threw it away. Can I get a replacement screen or do I have to buy a new MAF?
Old Apr 11, 2005 | 11:14 PM
Impala Balko
i removed them in my impala ss which has an lt-1 and i got no SES lights or negative performance issues thats why i was wondering about doing it on the vette. I know they sell the MAF ends which prettymuch do the same thing but i thought i read something a while ago saying that it is ok to remove the screen the imp ss and the f-bodys but the vette will actually kill performance by a tenth in the quarter and i was wondering if that was true or not.
Old Apr 11, 2005 | 11:15 PM
Impala Balko
by the way removing the screen is totally reversable on the LT-1s because there is just a ring that holds it in place once that is removed it just falls out
Old Apr 12, 2005 | 12:57 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
TJ, have you ever had the occasion to test this? Or is the modification value just not worth the efforts?
Old Apr 12, 2005 | 02:58 AM
siggy_freud's Avatar
siggy_freud
From what I know it can be worth the trouble of messing with the tables. However keep in mind your max airflow reading on L98's will always be 254 grams/second due to the fact that that is where the MAF output voltage maxes out. Dont know that cutting the screens would put you anywhere close to that at WOT (guess that would depend on the motor) but just something to think about.
To Descreening the MAF
Old Apr 14, 2005 | 10:54 PM
petdoc's Avatar
petdoc
Default Cop Car
I have a 9c1/LT1 ex-police car and was thinking about removing the screens. they might be for staightening the air but doesn't the process of staightening also cut down on airflow? What other Intake mods are worth buying... .58mm throttle body?, No-screen MAF(says it flows 45% more air), or cold air intake. Do these make a difference in horsepower. I have heard they do and I have heard they are a waste of money.
All Replies are appreciated
-Mark
Old Apr 15, 2005 | 10:23 PM
BadCop9C1's Avatar
BadCop9C1
I went to your ss impala site and loved it.
thanks alot for that recomendation impalabalko.
-mark (badcop9c1)
Old Apr 15, 2005 | 11:47 PM
1985 Corvette's Avatar
1985 Corvette
Hmmm, it helps L-98s if they intend to see high rpm usage which is kind of a chuckle when you think about it. I would imagine it helps LT-1s and 4s if they're going to see similar high rpm pulls/runs.
