Clutch Fluids are compatible????
Old Apr 12, 2005 | 02:54 PM
vvv90's Avatar
vvv90
Default Clutch Fluids are compatible????
I was searching the archives for what fluid to use for my ZF clutch and I'm a little confused.
I know you CANNOT mix silicone (Dot5?) with Dot3 in your brake system, but I hear people going with Valvoline Synpower Dot4 instead of the Dot 3 it says on our clutch master cylinder covers.
The Dot4 stuff is synthetic, but it isn't silicone is it?
Can you mix Dot4 synthetic with Dot3?
Old Apr 12, 2005 | 04:11 PM
rws.1's Avatar
rws.1
Valvoline synpower is not silicone and it is both DOT 3 AND DOT4.
You can mix it with DOT 3 if that is what is in your system. But if what is in your system is old and dirty you should replace it.
Old Apr 12, 2005 | 04:31 PM
vvv90's Avatar
vvv90
Thanks, that's all I needed to know.
I am going to flush the whole system anyway.
To Clutch Fluids are compatible????
