Plenum Porting - EXPERIENCED ADVICE SOUGHT
I don't agree with this quote, I added a paxton to mine and didn't need larger injectors.
I also ported the plenum and matched the runners..... it was a noticeable performance gain. i say go for it.
But anyway, I removed mine and didn't notice any adverse affects, I didn't seem to notice any significant seat of the pants improvement either, but it made me feel better that the inlet was (seemed to be)more free flowing.
I did the streamlining of the plenum to runner mods as well. I would have thought that the extra metal in there is for durability and strength and the modest reduction in flow wasn't an issue for GM. A lot of people who run siamesed runners cut most of this out anyway!
As for us enthusiasts, well we don't mind compromising durability in the name of performance do we? We do it all the time, porting heads, MAF's, etc, etc, all in the name of improving airflow in and out of the engine. IMO Just do it, if it breaks, don't do it quite as much on the next one. More air in, more power out with a proper tune. Just plan on making sure you clean the throttlebody more regularly than every 100 thousand miles owners tend to clean them and you probably wont have a problem
This has been the most comprehensive reply to date and your thoughts on EGR reversion hold merit with me; I cannot for the life of me see GM deliberately engineering the damns for NO REASON! B4 reading this I just posted a new thread to try and get more feedback.
Only thing IS; given that vacuum sucks (no pun) towards the windscreen, what conditions would you imagine would have the EG's blowing FORWARDS onto TB plates?
There are many unusual things that happen in an internal combustion engine, I'm sure there are many scientific reasons for this, it may be transients in vacuum/airflow when throttle blades are snapped open or snapped closed causing reversion, defective egr valves, passing when they should be closed, maybe poor sealing of intake valves allowing combustion gasses into the plenum, high overlap cams (not in the case of a L98 mind you) or just one of those phenomena's that just happen.
It happens to most engines, at least all that I have had, from carbed engines to fuel injected. The inlet tracts eventually get a build up of carbon/gum and combustion by-products.
Dave
Dave
On my 85 I "HOGGED" the plenum and was very pleased with the effect.
Getting the L98 to breathe has been a mission for me!
I, like so many others here, opened up the TB to 52mm and all that extra material in the plenum had to get outta the way. I gasket matched the plenum to runner bores but haven't done anything to the intake yet. But in front of all of that I opened up the air cleaner lid and added a K&N filter, smooth TB inlet hose and then removed the screens from the MAF. I have LT headers and true duals (sans cat but with crossover) to 40 Series Flowmasters on the exhaust side. And that doesn't include the internal changes...
So, did any single mod make the difference? Probably not but GM engineered the car for the masses...the "put the key and go" mindless drones we pass on the street everyday. That's why we don't wave to them but only to each other! We re-engineer/refine our cars to our individual (albeit collective) tastes.
Was the car quick before all of this...yeah guess so.
Is it quicker now...HELL YEAH!
Point is have fun...hog out the plenum and see what happens. If you don't like the change you can replace it with one from ebay for around $50.
Last thing...gotta mention...
FUEL PRESSURE! Get an AFPR and set that puppy just a smidge under 50psi.
