Lt4 tach swap from LT1
Old Apr 15, 2005 | 08:23 PM
rsafier's Avatar
rsafier
Default Lt4 tach swap from LT1
Okay so I got a nice looking LT4 cluster off Ebay, went to install today, everything worked good exact the tach, was about 1000rpm off. So idle was showing just about 0!
Reading about the swap didn't see anything might need to be changed, I'm assuming its a problem with the tach itself. Is this something that can be corrected or the unit is just junk?
Old Apr 16, 2005 | 03:45 AM
MaxLean's Avatar
MaxLean
I did the same swap and had no problems, at least none relating to the actual compatibility. The cluster that I recieved had a problem with the coolant temp gauge and there were some scratches on the lens. I basically only used the actual tach gauge and the main circuit board from the LT4 and everything else came from my stock cluster. In any event, there were no performance problems other than the tach reading approx 100rpm high, which is typical of factory tachs.
Old Apr 16, 2005 | 07:45 AM
Tom Piper's Avatar
Tom Piper
I'm not sure it this has anything to do with it, but here is a difference.
The '96 vehicles don't use a tach filter, the tach signal is conditioned square-wave generated in the ECM.
The earlier vehicles used a tach filter and filtered the tach signal from the coil firing waveform, which is conditioned, and this is passed to the ASR and tachometer.
Tom Piper
Old Apr 16, 2005 | 09:45 AM
rsafier's Avatar
rsafier
Yep thought about that, but don't have a tach filter in the system. I'm running a DelTeq, and before that was running MSD, both require removing of the tach filter. And when the filter is in the system you just don't get any tach.
I'm waiting a reply for the vendor. I can live with 1-200 rpm off, they aren't that accurate, but 1000 is unusable.
Is the tach movement dependant on the circuit board or the actual dial? If its just the board I could try swapping the dials on my units.
Old Apr 16, 2005 | 10:14 AM
-=Jeff=-'s Avatar
-=Jeff=-
did you swap JUST the tach or the complete cluster?
Old Apr 16, 2005 | 11:29 AM
tjwong's Avatar
tjwong
You can send the cluster in to a AC/Declo instrument shop and have it recalibrated for about $40. Jimmys radio repair in Phoenix used to do my clusters. They are an AC/Delco repair facility.
Old Apr 16, 2005 | 12:01 PM
rsafier's Avatar
rsafier
Complete cluster.
Old Apr 16, 2005 | 02:32 PM
pwrful c4's Avatar
pwrful c4
I did the swap in my 1994 and had no problems. I swapped the whole unit.
Old Apr 16, 2005 | 04:47 PM
MaxLean's Avatar
MaxLean
The circuit board is calibrated to the tach that is being used, I believe since the two tachs have a different scale.
To Lt4 tach swap from LT1
