C5 brakes for C4
Old Apr 19, 2005 | 12:53 PM
dndrsn's Avatar
dndrsn
The best thing i have done to my car so far. All parts except the hoses bought from forum members.
Old Apr 19, 2005 | 01:50 PM
crheinish's Avatar
crheinish
Originally Posted by IBEAM700
Ummmmmm...
Yep
very cool
Old Apr 19, 2005 | 04:20 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by purplemajesty
Have you tried the DRM bias spring? I have C5 calipers ready to go on and was wondering if it actually helped.
You need the bias spring or you'll worsen your braking distances.
Larger displacement front calipers and larger diameter rotor means less braking to the rears. You need the performance bias spring to get your rear bias back.
Old Apr 20, 2005 | 01:03 AM
SOLOC4's Avatar
SOLOC4
Originally Posted by QuikZilver
There are a couple of sites that sell the rear adaptors, but the rear adaptors are EXPENSIVE!!! (Front adaptors from Ed, mentioned above are less than $150, rears I have seen run over $300 and you lose your e-brake). At that cost, I would paint the rears and get rotors to match the front. Or, you can do what I did, upgrade the C4 to a Z06.
What does the C5 have for e-brake if it's not integral to the caliper?
Old Apr 20, 2005 | 01:31 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
It is similar to the 84-87 cars, it's a drum based design. Pad bites down on the inner part of the hub.
Old Apr 20, 2005 | 04:15 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Just a note of caution on the swapping fronts to rear. You have to be sure you have a good bias otherwise everytime you brake you will spin. Just something to look into for those considering it.
Old Apr 20, 2005 | 08:19 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Originally Posted by crheinish
very cool
I think I was the first to perform the C5 brakes on an 88-90 with stock wheels. I asked peeps on the forum if the stock wheels would clear or not and I got a 50/50 response of people saying they would or wouldn’t clear, so WTF ill just buy em and try em.
As you can see in the pics it’s a REAL close fit. You can’t even stick your finger between the caliper and the wheel it’s so close
Old Apr 20, 2005 | 09:14 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
No matter what they (stock sawblades, 90 wheels) will work with spacers.
Old Apr 20, 2005 | 09:24 AM
SDS Photography's Avatar
SDS Photography
so all yall are swapping is the cailpers?
IBEAM700's Avatar
IBEAM700
And that’s exactly what I didn’t want to do. Once you start adding spacers and changing backspacing you’ve screwed up the geometry of the suspension. The engineers put those wheels where they’re at for a reason, and since they know more about engineering than I do im going to leave em there
Old Apr 20, 2005 | 12:43 PM
4bblC4's Avatar
4bblC4
I think he meant putting the z06 fronts on all 4's.... not putting the c4 fronts on the back, and z06's on the front.....
didn't he?
Old Apr 20, 2005 | 02:01 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
didn't he?
No...all Z06 front brakes would be a bad combo. The idea is the old 12in fronts from the C4 would be moved to the back. I've been thinking and you would definitly have to get a proportioning valve or something. I'd love to hear any more info on this.
Old Apr 20, 2005 | 03:33 PM
  #33
CentralCoaster
Here's the way to guesstimate if you'll need a proportioning valve.
Figure this out:
(Front caliper piston bore X no.of pistons) X (Front rotor diameter)
Then do the same for the rear.
Divide the front/rear to get a ratio for the stock brakes.
Get close to this ratio with your new setup, and you won't need to mess with the bias or proportioning valve.
Figuring out if your master cylinder is large enough is a whole different calculation. I'm not gonna get into crack points, swept area, brake torque, now, but I plan on writing something up. There's way too many people just doing guesswork on brake setups. (I did the same) The whole thing has to be planned out as a package.
Old Apr 20, 2005 | 03:40 PM
  #34
luvmy92's Avatar
luvmy92
Figure this out:
When I installed the 6-pot Wilwoods in the front the pedal travel was severe before they would bite. And on a road coarse it was pretty hairy sometimes when they would get really hot. They would always bite (never faded) but there was a lot more play in the pedal.
After adding the 4-pot Superlites in the rear the stock MC just couldn't provide enough fluid to everything, so I opted for a Yukon MC with a much larger piston. I also added the Wilwood proportioning valve to handle the bias. I still don't have them dialed in but will in the next couple of weeks.
I was told to pull the abs/asr fuse, and then do a number of hard 60 - 0 stops turning the bias towards the rear after each one until the rears finally lock. And then turn it back a notch and you are set.
Mike
Old Apr 20, 2005 | 06:06 PM
  #35
Light84vette's Avatar
Light84vette
Can C5 brake calipers be used on an 84? I also only have these 16inch rims so I dont know if they would even fit inside the wheel.
Old Apr 20, 2005 | 06:21 PM
  #36
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
You need 17" rims to clear the calipers. A-molds work....
Here is a shot of the caliper and 17" rim.
Old Apr 21, 2005 | 06:25 AM
  #37
larryfs's Avatar
larryfs
with the Z06 calipers, do you use Z06 rotors? or C4 rotors?
the Z06 rotors are much cheaper.
To C5 brakes for C4
Old Apr 21, 2005 | 09:03 AM
  #38
IBEAM700's Avatar
IBEAM700
C5 calipers go with C5 rotors, and they are not interchangeable with C4 equipment
Old Apr 21, 2005 | 10:04 AM
  #39
Alzado77's Avatar
Alzado77
I'm in the middle of an upgrade to the 13" HD GS brakes. I've purchased everything I need but I have a question. Does anyone know if the bias spring is different on the GS then on the 12" brakes? They both use the same size brake pads so I'm thinking the upgrade might not be a large enough difference to need a different spring? I've heard a 10% increase in braking power but of course everyone advertises a HP or a percentage that usually isn't accurate. With the pads being the same size i'm thinking any braking improvement will be a result of better leverage due to the larger rotor and the outer edge of it traveling a greater distance due to being slightly larger? Am I thinking correctly and does anyone know if the spring is different? Thanks!
Old Apr 21, 2005 | 10:51 AM
  #40
90SteelBlueCoupe's Avatar
90SteelBlueCoupe
I was told by someone at VetteBrakes you need a new spindle... The 84 spindles were different from even the 85 ... I was told ... You might want to check this out first....
just my .02$
They will not fit inside the 16" wheel.. but will inside the 17" salad shooters...
