Super Charging?
Old Apr 24, 2005 | 04:04 AM
cplonner's Avatar
cplonner
Default Super Charging?
WHAT IS THE HIGHEST COMPRESSION RATIO YOU CAN HAVE WHEN SUPER CHARGING A 350 AND HOW MUCH PSI CAN YOU PUT INTO IT?
BASICLY WHAT WOULD YOU NEED AS FAR AS ENGINE CHARACTERISTICS TO HAVE A SAFE WORKING SUPER CHARGER ON YOUR CAR?
Old Apr 24, 2005 | 12:19 PM
tjwong's Avatar
tjwong
It depends on what you want to do. Most kits you will see offered for sale are designed to be installed on stock engines with 10:1 compression and up. Pro-Charger is offering kits for the LS6 engines with compression rations at nearly 11:1.
You should contact Greg at Blower Works. He has the best kits around for a stock L98 or LT1 or even the new ZO6 that is coming. Ideally if you are having an engine built, have it built for a blower application. For a street engine 8.5 to 9:1 is ideal, at that compression you can boost it up to 14 PSI for the street with the proper intercooling. 8 PSI would be a good average, 14 is in my opinion the max for the street using a supercharger. With boost past 8 psi you will need a minimum of a 8 rib drive or a cogged belt setup. Both of which is not a normal setup from a blower vendor. Most stock kits come with a 6 rib drive.
Old Apr 24, 2005 | 09:25 PM
cplonner's Avatar
cplonner
SO MY 10.0:1 COMPRESSION ENGINE IS PUSHIN IT FOR A BLOWER ISNT IT.
Old Apr 25, 2005 | 07:40 AM
ASRoff's Avatar
ASRoff
You cant run much boost on a stock engine with 10:1
I wouldent run much boost with the crappy cast Mahle pistons anyway they tend to break ring landings.
An Lt1 is a good foundation to build a "pressureized engine" due to the reverse cooling.
But, the stock computer is not up to snuff. They have been very hard to tune with boost.
I plan to run a turbo very soon (Turbos are harder to install but make more power.) (no paricidic loss).
Check out the Forced induction/ nitrous forum. There are alot of knowledgeable folks there (ask Baldturbofreak)
Old Apr 25, 2005 | 11:52 AM
VB Black Ice's Avatar
VB Black Ice
Should be in C4 Forced Induction / Nitrous
Old Apr 25, 2005 | 12:43 PM
Perfusion's Avatar
Perfusion
And a suggestion....lose the "ALL CAPS" - it's taken as shouting. Welcome to CorvetteForum, though, and best of look with your search!
To Super Charging?
