Pull the seat cushion bottom out (there's a latch in the front), then remove the four bolts that hold the seatback and the bottom down, then you can get to the drive assembly.
Maybe one of the linkage cables became disconnected... From there you can remove the drive assembly, I know you can purchase new ones but I don't know about rebuilding it.
