89 Temp control problem
Old Apr 28, 2005 | 09:04 AM
vetteluvers's Avatar
vetteluvers
2nd Gear
Default 89 Temp control problem
I have an 89 C4 that is constantly blowing hot air no matter what temp setting I have selected or whether or not it's set to auto or manual. At first I thought the A/C needed freon servicing but the A/C is working but not getting inside the car. A friend mentioned that there is a "blend air door/motor" that may be failing which may default to the heat side. With summer coming I need to get this figured out.
Old Apr 28, 2005 | 09:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
This should help you out (from my 86 manual)
http://members.shaw.ca/agent86/AC%20Electronic.pdf
Old Apr 28, 2005 | 09:58 AM
vetteluvers
2nd Gear
Thanx Agent86! Did this come from the factory service manual?
Old Apr 28, 2005 | 11:41 AM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I had the same problem a couple of years ago. It turned out to be the programmer. One of the resistors was burnt up.
Old Apr 28, 2005 | 03:15 PM
AGENT 86's Avatar
AGENT 86
YES
To 89 Temp control problem
