Anyone using the 749 ECM?
Old Apr 29, 2005 | 02:59 PM
Fatt Vette's Avatar
Fatt Vette
Default Anyone using the 749 ECM?
I am planning on using the Syclone/Typhoon ECM and a '91 Corvette MEMCAL. Anyone out there well versed on making changed to the this chip with the $58 mask? I need to change it from V6 to V8, turn off any fuel cut outs, etc...
Any Thoughts?
Thanks,
Old Apr 29, 2005 | 09:17 PM
ANTI VENOM's Avatar
ANTI VENOM
I will be using a 749, and it is installed, but I have yet to comunicate with it. My turbo project is momentarily stalled. As far as the $58 and 6 to 8 cyl. that is as simple as clicking in the 8 cyl box. I have a 91 and will also use the memcal. Wiring it in would seem to be a bigger problem than changing the chip. I do have tuner cat and a stock bin to look at. I'll help if I can, but I don't have all the answers..................yet!!! Good luck..
Old Apr 30, 2005 | 12:51 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Any Thoughts?
Thanks,
I just hacked up the 93 LT1 Da stuff to work with a 2 bar. Lots of things didn't work at first but I managed to fix everything up after about a year worth of playing with it.
2 bar stuff is kinda nice but in alot of ways its a whole new can of worms when it comes down to it.
Old Apr 30, 2005 | 05:47 PM
ztrips's Avatar
ztrips
Now this sounds interesting... Can you tell us more?
Old Apr 30, 2005 | 11:25 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
It works good, i've been driving it for over 2 years like this with both roots and centrifical blowers.
It handles 15psi pretty confortably and has enough resoulution in the VE and spark tables to give 0 problems even with a open loop tune.
Old May 1, 2005 | 12:35 AM
bigcityvette's Avatar
bigcityvette
Are these computers by GM comparable to the big name brands out there? Bigstuff3, F.A.S.T., Accel DFI, etc? I see bigstuff3 has a ton of features on it.
Old May 1, 2005 | 06:33 AM
ztrips's Avatar
ztrips
email on the way...
Old May 1, 2005 | 02:12 PM
ED89's Avatar
ED89
I have had mine in the last few years. It works well.
Old May 1, 2005 | 07:08 PM
Baldturbofreak's Avatar
Baldturbofreak
We've been using it(2 bar on Da32 mask) on bruce's car, so far there has only been a few quirks. Has anyone gotten datamaster to report the proper Kpa range? Ive gotten it to report correctly in tunercat by editing the tables with the definition file editor, and chaniing the map scalar to provide the proper range, however to get it to run correctly I still have to report the injector flow rate as being half what it really is. anyone else run into this? It works and is only a minor annoyance to me, but Id like to fix it. any ideas?
Old May 2, 2005 | 08:47 AM
Blower91's Avatar
Blower91
Does anyone know if the $58 code is working with the CCM? If you do the swap, will e.g. the milage calculation still work? Will the ECM do the $F1 poll? Will the DTC reading via the CCM still work?
Old May 4, 2005 | 01:14 PM
dgoodhue's Avatar
dgoodhue
I highly doubt it will work. The 730 ECM didn't work with the 165 Dash's function's.
Old May 4, 2005 | 01:17 PM
dgoodhue's Avatar
dgoodhue
I think Datamaster works properly for 2 bar scaling. Do you have datamaster for 749's? Did you set the map in the options for 2 bar?
Old May 5, 2005 | 09:52 AM
Baldturbofreak
No I don't, The ecm/ mask we're using is the stock 93 lt1 with the Da2 mask. I obtained a hard copy of motorola's opcode. Im going to work harder with the disassembly to find ALL calcs the refer to the map sensor's address and change them. It occasionally does some quirky ship.
So other than adresses of certain functions, I would assume the $58 mask would work in other ecms. Anyone disagree?
Old May 5, 2005 | 10:43 AM
tjwong's Avatar
tjwong
The GM OE computers actually have more control capability than the aftermarket ECMs. But tuning them is a pain as compared the the aftermaket ECMs. The big thing that the aftermarket ECMs give you is the capability to tune them live. You can't do that with a factory ECM. Well you can sorta, with the use of a emulator, but with the aftermarket you can see what cell the ECM is looking at for fuel and timing and other maps as well. The factory ECMs has much more processing power IMHO than the aftermarket stuf not to mention the price and the availability of a factory ECM is much better than a aftermarket.
Old May 6, 2005 | 08:32 AM
Baldturbofreak
For sure! All we have to do is put our collective heads together and write a mask specifically for all our needs- boost. With wastegate control, how bout using say the zr1 ecm and have 16 injector control.
Old May 6, 2005 | 11:35 AM
bigcityvette
One thing about the GM computers is they cost alot less than the aftermarket ECM's but like you said tuning is not the same. Plus I do not know how much of a warranty the aftermarket ecms have but im 100% confident a replacement GM ecm is less than a replacement DFI setup. I got my '7730 ecm from a Chevy Beretta in a junkyard for $10
Cant beat that. Hopefully I can use it in my next project........forced induction.
BTW Tom since you are a supercharger guru feel free to comment on my thread "good start for forced induction"
Im looking for feedback on a supercharger application for 360 c/i sbc.
Old May 30, 2005 | 01:18 PM
Fatt Vette's Avatar
Fatt Vette
Still lookin' for a volunteer to cut me a chip.
Thanks,
To Anyone using the 749 ECM?
Old Jun 6, 2005 | 09:00 PM
ANTI VENOM's Avatar
ANTI VENOM
If I could communicate with mine, then I would know that I burned the chip correctly. My cable may not work with the 749 ecm. I don't have a problem burning the chip, but I may not have it all worked out. If you don't have time to experiment, then I can't help. If you still have some time, then I may be able to get mine right and then duplicate it. It has been awhile since I burned mine and I can't remember how big those chips are or where to start the burn. I'll look into it again and let ya know how it goes!
Old Jun 7, 2005 | 01:47 PM
ED89's Avatar
ED89
Thanks,
You need to burn your own chips to meet your specific needs. Some instructions are located at the following locations:
http://www.moates.net/fileman/index....Tuning%20Notes
wiring, aldl for tunerpro, xdf for tunerpro and the most important the p4 doc(download it, learn it):
http://www.nwstp.com/
and one of the most comprhensive editors, PROMGRAMMER can be found:
http://www.nwstp.com/tech/default.htm
The v6-to v8 is selectable in the xdf. Egr needs to be disabled(adjust egr enable temp to 255) or patched to run properly with a v8 and there is also a 3 bar patch. Patches can be found www.thirdgen.org use the search function.
Souce code for $58 and $60(32k version) can be found at:
165-7730/7749 swap
http://thirdgen.org/techbb2/showthre...hreadid=221968
7730/7749 to 7727 pin conversion
http://www.cruzers.com/~ludis/quadplugecm.html
For individuals who wish to run P/H injectors in a weather pack ecu 1228708(see low z conversion for 7749)
http://www.thirdgen.org/techbb2/show...hreadid=260849
GM 1227749 Mods for Low Z Injectors
http://mywebpages.comcast.net/p-928/749mods.html
Old Jun 17, 2005 | 01:13 PM
Rkreigh's Avatar
Rkreigh
I think the brits had a version of this computer (carlton??) that was designed for boost.
I know gm did some test cars like the cerv that had a twin turbo LT5.
staged injectors is pretty cool, and SGC and LPE, Callaway, Mallet, Gieger have all built twin turbo LT5s.
I think with the modern wide band stuff on the XFI and the BS3 (or better still the Motec) that would be the way to go, but you need to also figure out the dash. I would be tempted to run "old school" gauges on such a radical project as they disco danny dash I could do without.
Never had much chance to play with this fancy stuff, only done turbo buicks which are pretty ez as the ecm was designed for boost from the get go.
