1986, which octane????
Old Apr 30, 2005 | 01:01 PM
jeremy carl's Avatar
jeremy carl
Default 1986, which octane????
noticed a knock/ rattle coming from the engine of my '86 at low revs and was running it on 85 octane. So for the hell of it I went up to 91 octane and what a difference, its like a new engine.
What does everyone else run their C4's on??
Old Apr 30, 2005 | 01:07 PM
Red Tornado's Avatar
Red Tornado
jeremy, your '86 is a 9.5:1 (ostensibly) compression vehicle. 87 octane should be the minimum. i would run 87 or 89.
91 is probably just a wallet-lightener. try all 3 and find out which your engine can tolerate the best......i'm betting 89 is your ticket
Old Apr 30, 2005 | 01:11 PM
vader86's Avatar
vader86
Shouldnt need more than 87 octane.
Old Apr 30, 2005 | 01:41 PM
scorp508's Avatar
scorp508
Originally Posted by jeremy carl
....what a difference, its like a new engine.
91 octane is more stable, allows for more compression, and less powerful (as is every octane grade higher). It sounds like the 85 couldn't take your car's compression & spark timing which I'm not surprised of. 87 or 89 should be plenty for a stock L98.
Old Apr 30, 2005 | 02:11 PM
jvette44's Avatar
jvette44
89 0ctane for me!
Old Apr 30, 2005 | 02:43 PM
Draven's Avatar
Draven
St. Jude Donor '14
I run '93. The place I get gas runs out of the lower grades all the time and he sells the '93 at 87 prices when thats all he has. I just make sure I catch him on a monday / tuesday before his truck comes in. ; )
Old Apr 30, 2005 | 03:03 PM
Alzado77's Avatar
Alzado77
I run 93 in mine but have used 91 and 89 with no noticeable difference. I've heard of more carbon buildup with the lower octanes so figured the I'd play it safe seeings it's not that much more.
Old Apr 30, 2005 | 06:34 PM
rws.1's Avatar
rws.1
93 Octane. because the premium has more detergent to keep the engine cleaner.
Old Apr 30, 2005 | 06:42 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I run 87 and a half scoop of Tide with Color-safe bleach.
Old Apr 30, 2005 | 08:48 PM
rrubel's Avatar
rrubel
FWIW, the 86 owner's manual says 87 octane minimum. If you buy from a decent gas station, all grades should have the same detergents in them...
I ran just fine on 87 once I hooked up the knock sensor that some former owner had disconnected and tie-wrapped to the frame .
[RICHR]
Old Apr 30, 2005 | 10:12 PM
GreyHairedTopGun's Avatar
GreyHairedTopGun
Default Detergent additives
All grades do not have the same additives package. The highest grade has the best package. It's not all about octane.
Old May 1, 2005 | 12:54 AM
PierEagle's Avatar
PierEagle
I only put about 4500 miles/yr on the car so I use 91. If it were a daily driver I would probably go with 89. As someone said on another thread, 89 is 87 and 91 mixed by the pump so you should be getting the additives in each also.
Old May 1, 2005 | 01:51 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
At $2.96 a gallon and $2.93 I just use the expensive one.
I still get a ping at times.
Old May 1, 2005 | 09:54 AM
rrubel's Avatar
rrubel
Once again, it depends on the brand. Some companies, like Enroy (sold at Royal Farms) make a big deal about how even their lowest grade has the same "protection" as their highest. Others, like Texaco, are the opposite. And Amoco seems to switch back and forth. Sometimes they say all grades are the same, and then a couple months later add something different to their 93. And Sunoco uses the same base for all their grades, mixing it in different proportions to get 94, 93, 91, 87, and 85 at one pump (at least around us).
[RICHR]
Old May 1, 2005 | 11:40 AM
Bilyk's Avatar
Bilyk
I use 87 with zero problems on my 1985. And thats without those fancy 86 aluminum heads.
Old Jun 6, 2005 | 04:17 AM
Casethecorvetteman's Avatar
Casethecorvetteman
I use 98 octane in my 94, and always used the same in my 87, or 95 if the 98 was not available. Im not sure if you guys have 98 octane fuel over there, but here in Australia, 91 is regular unleaded, premium is 95 and OPTIMAX or ULTIMATE are 98 octane.
Old Jun 6, 2005 | 07:44 AM
jschoof's Avatar
jschoof
whoa. those must be metric octanes instead of standard.
that was a joke.
To 1986, which octane????
Old Jun 6, 2005 | 07:53 AM
Casethecorvetteman
that was a joke.
hmmmmm... VERY FUNNY....
Old Jun 6, 2005 | 10:12 AM
CFI-EFI's Avatar
CFI-EFI
The higher the octane, the slower it burns and the less power it produces. Octane ONLY suppresses knock or pinging. If an engine doesn't ping or the ECM doesn't retard the timing, you have enough octane. Excess octane can only serve to waste money AND performance.
RACE ON!!!
Old Jun 6, 2005 | 01:05 PM
Casethecorvetteman
garbage budrow...
