New injectors for L98?
Old Apr 30, 2005 | 01:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default New injectors for L98?
In the past I've seen two sources of fuel injectors that seemed a good deal; search did not turn up the links.
One was the Ford 24lb/hr SVOs and the other was stock size GM injectors pulled new and sold off at a discounted price.
I would prefer a link to the latter but will consider the SVOs if I cannot find the GMs.
Thanks in advance for any leads here.
Old Apr 30, 2005 | 01:18 PM
scorp508's Avatar
scorp508
Jim, I would bet Rich could put a set together for you.
http://www.cruzinperformance.com/
Old Apr 30, 2005 | 01:31 PM
65Z01's Avatar
65Z01
Thanks Brian, I hadn't thought of him as a parts source.
I didn't want the down time of sending my stockers to him this time.
Old Apr 30, 2005 | 01:39 PM
darkred91's Avatar
darkred91
I got mine from fiveo last year www.fiveomotorsport.com
Old Apr 30, 2005 | 01:42 PM
Red Tornado's Avatar
Red Tornado
Jim, if you decide on FMS 24# blue-tops, p/n 9593A302, use this source:
http://www.buyfordracing.com/shop/pr...roducts_id=359
They're THE cheapest I could find when I was hunting for a set last year.............$189 + $10 shipping
Old Apr 30, 2005 | 02:36 PM
Morley's Avatar
Morley
Ask and ye shall receive!
http://www.slponline.com/view_product.asp?P=23051
Ignore the part about not fitting TPI...they do, I have them on a 91 Firebird and an 85 IROC
Old Apr 30, 2005 | 04:48 PM
65Z01's Avatar
65Z01
Thanks for the P/Ns and links guys.
BTW Morley, I checked on those SLP injectors and found the message you indicated. Then i did a parts search for L98 parts and came up with the same P/N (23051) at the same price ($99.95) without the caution message....lol. So these are looking like a prime candidate right now.
Does anyone run these SLP injectors on an L98 Vette?
Old Apr 30, 2005 | 10:35 PM
JIMBO7's Avatar
JIMBO7
I have a set but I haven't put them in yet. I would like to hear about other experiences with them too.
Old Apr 30, 2005 | 10:49 PM
65Z01's Avatar
65Z01
JIMBO7 are yours going into a Vette L98?
Old May 1, 2005 | 12:11 PM
JIMBO7's Avatar
JIMBO7
65ZO1 I'm driving a 1988 Met. Red Coupe. stock motor, 85k miles.
I'd like to get some input on their performance before I install them too! I seem to recall some input on the forum about them last year, but don't remember if it was okay or not.
Maybe Morley can chime in with his experience!
Old May 1, 2005 | 12:35 PM
65Z01's Avatar
65Z01
Yep, I too recall some negative feedback on a certain brand of injector; I think it was Accels but not positive.
Old May 1, 2005 | 02:55 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86 is basically stock and the 22lb Bosch's were $205 delivered from Five-Ohs Ebay site.
Old May 1, 2005 | 03:23 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
When installing new injectors, what gaskets am I going to need to ask for?
Old May 1, 2005 | 04:17 PM
65Z01's Avatar
65Z01
If this is the first time your runners have been off you likely should replace the upper & lower runner gaskets and maybe the TB gasket.
Since mine are on/off regularly I'll likely reuse my gaskets. The injectors (SLP) show that they come with O-rings on each end so those are not an issue.
Since I pull and buff my fuel rail each time I always have to use some rubber tubing and hose clamps to loop between the two fuel lines. Otherwise those damn things ALWAYS insist on emptying my tank on the front of my engine.
Old May 1, 2005 | 08:23 PM
bark3711's Avatar
bark3711
This is an interesting discussion....I have a mostly stock '90 coupe and have been weighing the pros and cons of upgrading the injectors. I'd appreciate some input about the benefits of such a swap.
Old May 1, 2005 | 08:57 PM
music_man's Avatar
music_man
From: Cicero, IN "Change is inevitable, except from vending machines"
Not sure about previous feedback, but I am running the Accels 22lb injectors from Summit Racing and have had zero problems.
Oh Yeah - mines a 90 Vert.
Old May 1, 2005 | 09:43 PM
TA's Avatar
TA
Jim, if you're considering the FMS injectors there is (or at least was) a guy who sells them on Ebay for $150 plus shipping. I'll see if I can locate one of his auctions.
To New injectors for L98?
Old May 1, 2005 | 11:03 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I got mine last winter for around $180
For the first time i hit 30mpg average I must have been half a sleep to drive the tame
Old May 2, 2005 | 08:46 AM
JackDidley's Avatar
JackDidley
I have the LS1 take outs from SLP. I took a steak knife and cut the groove for the clips. The factory groove on them does not go all the wway around so you just have to complete it. They had no gas smell so I don't think they had ever been run. Working good for 16 months so far.
Old May 2, 2005 | 09:38 AM
65Z01's Avatar
65Z01
Those SLP LS1 pulls are looking very attractive at $112 to my door.
If indeed the retainer clip groove is the only issue with them I'll cut the order today.
My reason for going with new injectors is a nagging lean condition at WOT. I've replaced the fuel pump and have solid pressure, with only a slight dip just after going to WOT, so I'm looking at the injectors as the problem cause. At ~$100 for a set of 8 injecors it's a trade off between going new or sending the OEM set to Rich; and going with the new will mean no real down time.
bark3711, unless you are having fuel delivery or leaking problems there is no reason to "upgrade" from your stock injectors with only minor mods. It is better to install an AFPR and adjust fuel pressure for optimum fuel delivery at WOT.
