Speedometer Gear Calibrator
Old Apr 30, 2005 | 05:41 PM
Jmsbond007's Avatar
Jmsbond007
3rd Gear
Default Speedometer Gear Calibrator
Does anyone know how to wire this thing in ??? where do I put it ??? The directions provided are vauge. Thanks for anyones help.
Old May 1, 2005 | 08:15 AM
C10 JDR's Avatar
C10 JDR
What make is it? What does it look like? link?
In the absence of any info, I would guess in the wire from the VSS.
Old May 1, 2005 | 12:19 PM
CFI-EFI's Avatar
CFI-EFI
Buy the correct speed parts, then, the "where do I put it", becomes the garbage can.
RACE ON!!!
Old May 1, 2005 | 12:34 PM
LD85's Avatar
LD85
What is the application?
I hope it is not a ZF with a 3.07 rear, cant be done easily without a specially made tranny gear from ZF doc.
Old May 1, 2005 | 01:32 PM
SuperL98's Avatar
SuperL98
If you have the Abbott Electronics Box, Sold by Zip or Jim Pace, etc.
I just hooked one up to an 1988 automatic and it works just fine.
If you have a different year, not sure this will help.
Two wires going to the VSS at the rear of the trans, purple and yellow. Cut/splice into the yellow wire near the trans.
White wire, from box to the VSS/trans side of the cut yellow wire.
Blue wire, from the box to the ECM/car side of the cut yellow wire.
Switch settings ratio, if you haven't changed the old vss & speedo gears, is your old ratio divided by the new rear ratio.
Example 2.59/3.54 = .732
I mounted mine behind the passenger side dash/crash panel.
Drilled small hole in the floor near the shifter and ran the wires up under the dash.
But I had already replaced the dash pad with a guage panel, so it was easy to get behind it and hook up 12volts.
Old May 1, 2005 | 06:27 PM
Jmsbond007's Avatar
Jmsbond007
3rd Gear
Sorry about that, here is the link to the item I purchased ....
http://www.abbott-tach.com/era.htm
Well that was a little long. Thanks for the advise so far. Yes it is an Abbott electronic ratio adapter.
To Speedometer Gear Calibrator
