Thread Chaser
Old May 2, 2005 | 08:22 PM
dan6712cc's Avatar
dan6712cc
Default Thread Chaser
Does anyone know what diameter and pitch thread chasers I need for the heads on a 94 LT1?
Also is it necessary to chase the threads for the intake manifold if you're putting new gaskets in?
Old May 2, 2005 | 08:29 PM
Pete K's Avatar
Pete K
3/8 16 is the thread for intake holes. I think 7/16 14 is the head holes. I will go check now.
Wadda you know! I was correct. I use special thread chasers that resemble a dull tap. They have no cutting action so no metal is removed. Only junk is cleaned out.
Old May 2, 2005 | 08:36 PM
dan6712cc's Avatar
dan6712cc
Thanks, I'm replacing the head gaskets this weekend and just remembered I needed to do this
To Thread Chaser
