Paging TJWONG
Old May 4, 2005 | 06:06 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Paging TJWONG
Hey TJ,
I have a mysterious little 'issue' that is driving me bazonkers.
SD, TPI, '727' ECM, $8D code.
No EGR, No CCP, No VATS.
I have the infamous RPM Flareup at start.
Engine cranks up just fine, runs great, BLM's & INT's 128 +/- 5 across the board.
Runs really good in all modes.
Here's the 'issue':
On warm starts the engine RPM will jump up to 1400/1500 RPM and immediately settle back down to 800 RPM.
Actually it does this on cold starts but on a cold start I 'kind' of expect this.
Doesn't matter what the engine temp is. 180* and on start it jumps up to 1400 to 1500 RPM and takes about 1~2 seconds to come back to the idle speed I have in the EPROM which is 825 RPM IIRC.
I've adjusted the IAC park position down to 25. Hasn't affected it at all.
The Park/Neutal switch is working.
I've adjusted the IAC Learn Min & Max Temp down to values that the engine will experience while running.
The idle is constant/steadyno issues with 'roaming idle' speeds.
It just is driving me nuttazoid trying to control this and not finding anything that affects it or even changes the characteristics at all.
I'm wondering if there is a time lag before the MAP is sensing the run Manifold Pressure and the ECM is trying to compensate by opening the IAC up quickly during the start sequence.
Got any ideas what I can try to stop the start idle rpm flare?
Old May 6, 2005 | 02:56 AM
tjwong's Avatar
tjwong
Try performing a minimum air rate adjustment. With the IAC totally closed set the throttle stop screw so that the engine idles at approximately 550 to 600 RPMs. Before doing this, its a good idea to clean the throttle plates and the body. Double check the TPS adjustment as well, and check the TPS for a linear output. I have seen older TPS sensors do weird things after thousands of miles of use. I had one that drove me nuts, the voltage was actually varying on its own without any throttle movement.
Old May 6, 2005 | 11:19 AM
Timmy!'s Avatar
Timmy!
That's what happened to my TPS and I had to replace it. I couldn't figure out why the idle was going up and down, up and down and at idle it was varying itself somehow. I think I might have gotten it wet with TB cleaner and that screwed it up.
To Paging TJWONG
