Engine rebuild experts inside please
I'm not going to put something that looks like this in my engine regardless, but I want your opinions to decide whether to pursue a refund. It was represented by the seller as having no problems - taken out at 57k for an upgrade.
RACE ON!!!
Jake
GET YOUR MONEY BACK!!i have used stock cam in WAAAAAAAY better condition...stock cam ....taking offers
also, never buy used parts that move or rotate, ie, invlolve friction. fixed parts like intakes, probably heads (bare), etc. are a good bet no matter what mileage. but don't buy a camshaft for instance that had any appreciable mileage on it whatsoever. its more than worth it to buy new, in these cases..........especially, absolutely especially if you have to pay someone else to install it.
if you're a mechanic who does this stuff blindfolded, i suppose buying used parts, or cheap parts for that matter, have much less of an impact in the paranoia dept. but if you're playing for keeps, and need to buy better reliability - or at leats the perception of better reliability - then buy new.
This may not be necesarry true. I paid $325 LPE cam. I run for one year. I sold to forum member for $100. It all depends how honest the seller. The condition of the cam above, I would not attempt to sell to any one. But some out they will sell for what ever they can get for it.
Bruce
The problem with buying used parts, of any kind, is you have little information about the condition of the part when you hand over your money. You only know what you can see, and that does not reveal alot. I have bought entire engines, with the intention of rebuilding them, knowing that every rotating part might have to go, but hoping that much could be reused. But in that case, you can take the rotating assembly to a machine shop and have it checked out, polished, balanced, etc. You can replace the fasteners, pistons, cam, etc., but the price I am willing to pay for a used engine assumes the cam, lifters, pistons, oil pump timing chain, gaskets, and bearings are going to be replaced, and maybe the crank and rods. When it comes to checking things out, and deciding what to reuse, it's whether or not the crank and rods are good that determines whether you got a good deal. But the cam, never stays.
Here is an ethics question. I sold an engine a few years ago, and threw in the cam. The guy acted like the cam was the deal clincher. I didn't tell him not to use it, but the reason it was sitting around is because it came out of a motor I rebuilt, and thus got replaced with a new one. It MIGHT have been fine, but the point is, you can't tell by just looking, so giving it to him was easier than throwing it in the trash.
Was I acting unethically here?
