I must agree about leaving a mechanical gauge on the Schraeder valve.
I had the Accel gauge on till a dyno operator pointed out one day that the gauge was 1/2 full of fuel. Sure it was very convenient..up to that poiint. Now I just use the flex hose one from AutoZone.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by scorp508
I don't ever recommend installing an underhood mechanical fuel pressure gauge. I may just be psychotic and nervous, but the idea of one failing and fuel spilling all over a set of hot headers doesn't sit well with me. I prefer an electronic gauge with just a sending unit on the fuel rail.
With that said, I just use a FP gauge on a 3' rubber line that you screw on, set the pressure, and then remove.
Except maybe on a radical pure drag car where frequent adjustments might be made. It's very easy to hook up a temporary gauge when needed.
