thread lock recommendations?
Old May 11, 2005 | 09:35 PM
1987C4's Avatar
1987C4
Default thread lock recommendations?
I'm reinstalling my driveshaft tomorrow. I have a supply of the blue medium strength thread lock for the u-joint retaining bolts. I was wondering what you all have been using on yours? Is the blue medium strength enough or do I need to use the heavy duty red stuff?
Thanks for any replies!
Brad
Old May 11, 2005 | 09:46 PM
bogus's Avatar
bogus
that should be ok.
Old May 11, 2005 | 10:29 PM
M.Clough's Avatar
M.Clough
use the blue if you use the red and have to remove at a later date you are going to have fun
Old May 11, 2005 | 10:30 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Red should only be used on fasteners that you will not be wanting to come apart for quite some time. Blue is perfect for what you're doing.
Old May 11, 2005 | 10:48 PM
bogus's Avatar
bogus
Red is great for flywheels and clutches... things like that.
Old May 11, 2005 | 11:46 PM
1987C4's Avatar
1987C4
Thanks guys! I appreciate the replies. I used some of the red on the rear drive axle u-joint bolts. Wow! When I went to check their torque later, they were really tight (hadn't budged at all!)! Thought better about what I use on the driveshaft bolts this time around! Again, thanks!
To thread lock recommendations?
