Ls6
Old May 20, 2005 | 05:17 PM
wgc_3's Avatar
wgc_3
Default Ls6
What would it take to change out the engine from our C4's to an LS6?
here is what I have in mind someone tell me if I am right or wrong?
LS6 Engine
ECU
Wiring Harness
Other then those three items would you think it would fit perfectly or would other things have to to be changed out as well?
Would everything work correctly?
Old May 20, 2005 | 05:50 PM
mos90's Avatar
mos90
more hassle than its worth. you could build a 600 hp engine for your car for less money and headaches.
Old May 20, 2005 | 06:10 PM
4bblC4's Avatar
4bblC4
don't forget the tranny. I agree with mos90, but if you REALLY want to do it, just for the sake of doing it, cool! good luck to you!
Old May 20, 2005 | 10:34 PM
Ramanstud's Avatar
Ramanstud
I think what the other posts are trying to get at is that the motor mounts, transmission and transmission mounts, as well as the C-beam (connects to the tranny) would need to be modified or improvised. The ECM/Wiring harness wouldn't scare me much as I swapped those out in my 84 MPI conversion. but you may still lose certain dash readouts and whatnot depending on the year and features of your ride.
also, your fuel lines, air intake, coolant hoses, etc would all likely need to be tweaked with the installation of a completely different engine and accessory layout.
To Ls6
