Turbo Project Updates???
Old Jul 2, 2005 | 02:42 PM
  #41
GM_96LT4's Avatar
GM_96LT4
Originally Posted by qwiketz
Glenn, where are you going to get this stuff installed at? I'm in fullerton and haven't found anyone willing to work on my car.
qwiketz,
I goto a shop located in Ontario. They do great work, but just really busy.
Send me an email and I will send you their contact information.
glennmatthew@earthlink.net
Glenn
Old Jul 2, 2005 | 02:45 PM
  #42
GM_96LT4's Avatar
GM_96LT4
Originally Posted by Fozzy_Bear
I bought an aftermarket picture viewer. I paid for a shareware GIF viewer back before Windows had one included (around 1992 it was called, originally enough, WinGif) and about 3 years ago paid to upgrade it to the latest (at the time) version.
http://www.pixvision.com/
It has an edit tab with a resize button.
Fozzy,
You beat me to the punch. I was just about to post a link with the pictures.
Evltwin,
Thanks for the pictures - looks great, let me know how it's running in a couple of months. It's never too late to change my mind - However, that would leave me a couple of SC's to sell.
Anyway,
Good luck,
Glenn
Old Jul 2, 2005 | 03:46 PM
  #43
1985 Corvette's Avatar
1985 Corvette
Out of curiosity, where is the battery relocated on in those pictures of that C4 where the turbo seems to be located right where the bat should be. Also, I'm a newb to the turbo process: the heat sheilding is there to protect the turbo or the surrounding accessories? And I have to agree, that is one of if not the most impressive setup or improvision involiving placement of a turbo.
Old Jul 2, 2005 | 04:30 PM
  #44
evltwin's Avatar
evltwin
You are correct. The turbo is where the battery was. The battery is in the driver's side compartment in the hatch area (two storage compartments, one driver and one passenger side). I am still able to use the removeable storage bin, and the battery is underneath. It remains very accessible. I have had it back about a month now. The only problem I have noticed is that the stock cooling system is not sufficent. It is running about 215 -217 F. Prior it ran about 180. HP ordered me a 3000 CFM Spal (?) dual fan and wiring harness. It will be wired to kick on at a certain temp and when more than 2lbs of boost are generated. I have noticed no difference in normal driving conditions. It runs as good as ever. There is one difference, I am getting 8 -9 MPG better than before.
Old Jul 2, 2005 | 07:21 PM
  #45
mn_vette's Avatar
mn_vette
Are you going off of the calculator on the dash? If you changed your injector size this calculator will be off, just a heads up.
Old Jul 2, 2005 | 09:49 PM
  #46
evltwin's Avatar
evltwin
It is off. But I have checked it the old fashion way as well.
Old Jul 3, 2005 | 09:24 PM
  #47
qwiketz's Avatar
qwiketz
that's awesome. My car gets about 11-12 mpg, so I can really appreciate that one.
Old Jul 6, 2005 | 04:53 PM
  #48
bill mcdonald's Avatar
bill mcdonald
Originally Posted by mn_vette
Hey guys I'm just wondering where everybody is with their turbo stuff? I haven't heard anything in a while.
Anybody else have anything going on???
a bit of mock up work.
having issues with shutting the hood. may try and cut out the hood support rails.
or may have the headers rebuilt and mount the turbos lower if possible.
still want to run my TO4B's vs the T4/T3 in the pics.
