Help with leak please!!
I have the rear end jacked up to replace u-joints. Noticed I have a pretty good leak coming from the aft end of the drive shaft/front of diff. area. Is there a seal or gasket there that may need replacing? If so does anyone have the name of the part or better yet a part #. I don't want to re-install the drive shaft before I get this fixed. Any other idaes on the source of the leak?
Thanks in advance.
As for the part number my chevy dealer still had the seals fora Dana 44 in stock, so I did not need to hunt down the PNs.
