I am running CNC Cylinder Heads heads with 2.0I and 1.57e valves. Also running stock pistons. I bought the camshaft from Pete at CNC, and he says that with the duration of this camshaft, there will be no problems with piston to valve contact. Pete seems to think that duration causes a bigger concern of piston to valve contact than lift.
Zix, what was the duration of that camshaft?
I guess we will see this weekend, when I get time to finish this project.
Well, I'm taking a chance here and running a single spring, the Comp Cams 918's. These springs are advertised for a max lift of .600. But, with an installed heigth of 1.825, I'll have a .118 clearance before coil bind, and a 125lb seat pressure.
I believe those new "beehives" are the ones I'm going to have put on my heads. I take it you're pretty happy with them?
They are also on my list if I upgrade roller rockers to 1.7. I already have .566 lift with the 1.6's. These springs are good at handling a bit more lift.
I was running .575/.595" lift. The only real problem was that the valves were too big to fit into the stock piston reliefs. I actually ran the engine like this for about 5000 miles...never even knew it was happening until I took the heads off and saw the marks on the pistons. I'll take some pics of them late tonight...I don't have them here in front of me.
They are little on the costly side initially with the special retainers and seats, but I no longer have any issues. Admittedly, I also have a AFR Hydra Rev, but I honestly don't think it adds significantly...more of a little buffer before valve float.
The dyno was stopped at 6800 rpm as that was the goal. Later I regret not taking it to 7000 or even 7200 to see where valve float does indeed occur if at all. Adds more flexibility on the road course/autocrosses. An inreality it was dirt cheap as I would have paid more to rid the engine of a valve float issue that was lower than the stock redline!
Another thing it fixed was the valve seal to spring distance. My double springs were extremely tight to the seal...some seals were dislodged and destroyed, others had their sides polished. Just not a good deal for longevity...this was within 10,000 miles or less.
Besides my experience, there is quite of few magazine tests...Hot Rod, Muscle Mustangs, etc that have nothing bad to say about them...usually they gain 500-1000 rpm before 'valve crash'. I know they are mags, but David Vizard wrote a few of them and he tells it like it is typically.
The price I was quoted was only $100 more than the springs included on the Stage 3 heads. The more I think about it, the more I like the idea of going with them. The break down was basically $50 for the springs and $50 for the special retainers you just mentioned.
Well, I tried to start the car this afternoon. But, all it would do is sputter, smoke, and die. Looks like I installed the opti wrong. Seems like it just slid into place, I can't believe it would be that easy to install the 95/96 opti incorrectly.
Before I tear this thing back apart, any other ideas of what might be the problem?
