Camshaft Install
Old May 27, 2005 | 11:58 AM
STL94LT1's Avatar
STL94LT1
Default Camshaft Install
Well, I finally got a break from work, 4 day weekend. So, it's time to do the cam upgrade. Have already ordered and recieved most of the parts. Just need to get out in the garage and get started.
Oh, I'm installing a Comp Cams custom grind from CNC Cylinder Heads, and doing the 95/96 opti upgrade.
Wish me luck.
-Mike
Old May 27, 2005 | 12:02 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Good luck. Its quite a project. I'm glad mine is done.
Oh on the new opti when you are installing it be sure to keep one finger on the little rotr itself. It will try to spin on you very easily making it misaligned. This was my only screw-up during my install.
Old May 27, 2005 | 12:10 PM
sothpaw2's Avatar
sothpaw2
Wish me luck.
-Mike
Good luck buddy. Hope it gives you more power but ok emissions. Let us know in a few months when you (inevitably) dyno it.
Old May 27, 2005 | 12:27 PM
Gary04Z06's Avatar
Gary04Z06
Keep us posted on how it goes.
Old May 27, 2005 | 12:35 PM
JAKE's Avatar
JAKE
May the God of Engine Modifications smile on your efforts.
In case they turn a blind-eye, my advice is: Take your time, Pay attention to detail and Post here if you have a question/problem.
Jake
Old May 27, 2005 | 03:08 PM
LT4POWR's Avatar
LT4POWR
Hopefully I'll be doing the same this weekend.
Old May 27, 2005 | 04:45 PM
STL94LT1's Avatar
STL94LT1
Thanks guys, progress is going pretty well. Looks like I may have the camshaft out later tonight.
-Mike
Old May 27, 2005 | 06:40 PM
R23HTC's Avatar
R23HTC
Wish me luck.
-Mike
If your upgrading optis, I hope you planned for a new cam gear setup and front cover. They have to be changed as well. I got the Cloyes double roller and the '95 front cover on mine.
Old May 27, 2005 | 08:04 PM
cprgmr's Avatar
cprgmr
Putting in that 224/230 aren't you?
Old May 27, 2005 | 08:39 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Jake
Best advice ever!
Old May 27, 2005 | 08:55 PM
STL94LT1's Avatar
STL94LT1
Yep, got it covered.
Old May 27, 2005 | 08:59 PM
STL94LT1's Avatar
STL94LT1
Duration: 224/230
Lift: 568/584 (1.5 rocker ratio) 605/622 (1.6 ratio)
LSA: 112+2
Old May 28, 2005 | 02:22 AM
Dan Parker '96's Avatar
Dan Parker '96
Mike,
Hope the swap goes well. I may have to hook up with you on another dyno session. I just installed the EM headers (installation of extensions sucked with A4). But I think I gained a little pep. N2O may like it as well.
Let me know if you hit the mill.
Old May 28, 2005 | 07:56 AM
STL94LT1's Avatar
STL94LT1
Dan, hope to hit the dyno in a couple of weeks.
Old May 29, 2005 | 09:10 AM
STL94LT1's Avatar
STL94LT1
Well, the car is almost back together. The camshaft install the second time around sure is easier.
I still need to get some valve spring measurements, and decide which rocker ration I am going to run. If I stick with my current 1.6 ratio, this camshaft is going to have some crazy lift.
Old May 29, 2005 | 10:01 PM
ANTI VENOM's Avatar
ANTI VENOM
Can't wait to hear the results. Good luck!!!
Old May 31, 2005 | 09:44 PM
cprgmr's Avatar
cprgmr
To Camshaft Install
Old May 31, 2005 | 09:52 PM
ninetyfivevette's Avatar
ninetyfivevette
What springs are you using with that cam?
Old May 31, 2005 | 10:17 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Mike... that cam is huge!!! We need to run her again to see the progress on paper
I'm glad to see all went well. I'll touch base with you later
Old May 31, 2005 | 10:20 PM
Zix's Avatar
Zix
Are you running stock pistons and valves? I ask because if you are running stock pistons and larger vlaves you run the risk of hitting the valves agains the pistons with that much lift. I had an LT4 that did exactly that when I was running about .580" lift, but only because I was using oversize 2.055 intake vavles that did not fit into the valve reliefs cut into the pistons. Something to think about!
