The engine is in (pics)
Old May 30, 2005 | 02:45 AM
350ws6's Avatar
350ws6
Default The engine is in (pics)
Tomorrow the bellhousing and both trannys go in along with the C beam to finish the drivetrain mechanicals. Then the easy stuff like waterpump, starter,alt, hoses, cooler lines etc get connected.
After that the hard part is running the fuel lines and fabricating the plenum and throttlebody.
Here is the fuel system I bought,minus the 255lph pump and 48lb injectors. The fuel system is enough to support 650hp.
Old May 30, 2005 | 02:54 AM
bogus's Avatar
bogus
cool. way cool!
Old May 30, 2005 | 07:23 AM
Atok's Avatar
Atok
[QUOTE=350ws6Tomorrow the bellhousing and both trannys go in along with the C beam to finish the drivetrain mechanicals.[/QUOTE]
Pretty!
What do you mean *both* trannys?
I've never changed an engine in a C4 before. Can you not bolt the clutch assembly and bell housing to the engine before installation?
Old May 30, 2005 | 08:24 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old May 30, 2005 | 08:34 AM
Aquaman92's Avatar
Aquaman92
Wow nice job
Old May 30, 2005 | 09:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
Looks like you did some cleaning and painting before the install.
Old May 30, 2005 | 09:55 AM
350ws6's Avatar
350ws6
Originally Posted by Atok
Pretty!
both trannys, the 4 speed and the OD unit , you can bolt the bell housing up also, mine is out being media blasted right now it willgo in today tho
Old May 30, 2005 | 11:58 AM
loiq's Avatar
loiq
You're gonna run a Megasquirt system, correct?
Old May 30, 2005 | 12:05 PM
red L98's Avatar
red L98
lol, you work fast.
Old May 30, 2005 | 12:08 PM
FD2BLK's Avatar
FD2BLK
Swweeeeeet,
What did you do about the hood?
Old May 31, 2005 | 12:24 AM
350ws6's Avatar
350ws6
Yeah, megasquirt and wideband O2. Once the fuel system comes in it should only be a week or so until it is finished.
Old May 31, 2005 | 12:25 AM
350ws6's Avatar
350ws6
Originally Posted by red L98
lol, you work fast.
Thanks! I got the tranny and DS in today, along with the C beam. The waterpump, and pullies are on also.
Old May 31, 2005 | 12:26 AM
350ws6's Avatar
350ws6
Originally Posted by FD2BLK
Swweeeeeet,
In terms of clearance? I have a milled down TPI throttle body that I am making an adapter plate for. It just squeezes in.
Old May 31, 2005 | 01:58 AM
Curveit's Avatar
Curveit
First, It's all looking very good. Can you tell me more about the dual-plane intake...I'm very interested in this; It's new to me. I understand you're not going to use it...whyzat?
Old May 31, 2005 | 02:43 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Suh-weet! Looks like a million.
Old May 31, 2005 | 03:17 AM
Reddy94's Avatar
Reddy94
Old May 31, 2005 | 07:53 AM
350ws6's Avatar
350ws6
The intake is kind of special,It is a port injection design that works with the fastburn heads. I searched and finally found it on ebay. For the next motor I don't knowif it will be enough to support the airflow needed, But I may be wrong.
To The engine is in (pics)
Old May 31, 2005 | 09:22 AM
FD2BLK's Avatar
FD2BLK
I am a little confused, Are you using a TBI with an air cleaner or a plenum with a TPI TB? A pic would be great.
Old May 31, 2005 | 10:05 AM
350ws6's Avatar
350ws6
The intake has injector bosses, I made up two fuel rails, so 8 injectors total for port fuel injection. The TPI TB is just to meter airflow, It will be attached to a custom plenum and aircleaner.
Old May 31, 2005 | 10:07 AM
jimmers's Avatar
jimmers
thats real nice!
