Help with troubleshooting....
Old Jun 1, 2005 | 01:50 PM
illinest's Avatar
illinest
Default Help with troubleshooting....
I hear an irregular noise, not quite a click, not quite a ping, something in between...
It doesn't start making the noise until the engine heats up. Always pretty quiet at first but progressively louder and more frequent as the heat builds.
Took it to a mechanic and he said he "had no idea" but then he listened a little bit longer and told me that it sounded like it was coming from toward the front of the engine and that he suspected a pump was going bad. Water, oil, air, etc....
This set me to thinking..... a centrifugal pump (as I would imagine) should make a REGULAR sound whereas a positive displacement pump might make an IRREGULAR sound.
Do these symptoms spark anyone's memory? Any leads?
(86 TPI with aluminum heads, no modifications done to car.)
Old Jun 1, 2005 | 01:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My only advice is to move around the engine area and try to isolate it to a particular accessory.
Look for any pulley that wobbles if you can't isolate the sound and check the tensioner for proper setup.
Does it make the noise with A/C compressor on vs off?
Old Jun 1, 2005 | 03:00 PM
sniperdiver37's Avatar
sniperdiver37
I have found that Vetts just make noise. sometimes good one sometimes bad ones.
Here is a list of things that I found make noise.
Injectors
air pump
a/c pump
pullys & belts
even the air cleaner sucking air
I put it this way because I was tracking some noises also and found all this make noise.
Bad noises grind, sqeak, rattle, and thump. any other noise is just it working
Old Jun 1, 2005 | 11:27 PM
illinest's Avatar
illinest
Injectors
air pump
a/c pump
pullys & belts
Well it's a new noise, one that I've never had before in many thousands of miles. I think "clack" may be the right sound descriptor.
@ 65z01 - I'm definately gonna try that tomorrow. Doubt it's the AC cause I haven't had air conditioning since I got the car
To Help with troubleshooting....
