Clearing codes from the comp
Old Jun 5, 2005 | 12:08 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
Default Clearing codes from the comp
Gota quick question.
The other night on my way to work , the dreaded service engine soon light comes on. I drive the rest of the way to work, approx 10 miles or so cause the car was still running great, gauges were all in speck. Get to work , do the ol wire accross the A @ G pins on the connector (mines a 92). Although the SES light went out , i got the H32 (EGR Faliure) code. Sooooooo
I go out this morning with my scanner in hand, i figure ill try to clear the code. I have a AutoXray 3000 scanner. When i try to clear the code it gives me "Car not Responding" ..... Now i can read the code, See the code, and look at my real time engine info ,, just not clear the code.
So instead of beating my head over it , i figure their is probably some special way of clearing historic codes? So if anybody knows the trick , please let me know. Or is it just something to not worry about?
Old Jun 5, 2005 | 12:20 PM
tjwong's Avatar
tjwong
Really nothing to worry about, you can disconnect the battery to remove the codes. Or kill the battery power to the ECM but I can't remember exactly where to do that on your car.
Old Jun 5, 2005 | 02:56 PM
92ZR1WANNABE
So pretty much don't worry about it since its a historic code then?
Old Jun 5, 2005 | 04:03 PM
Morley's Avatar
Morley
Yes. If it doesn't come back it will self clear after 50 starts (or there abouts)
To Clearing codes from the comp
