Fuel pressure question
gets bad mileage (22 best ever), doesn't like starting when warm, all the signs of bad injectors.
Hooked the fuel pressure gauge to it today.
Idle pressure- 38psi
1000RPM-35psi
engine off-44 psi
5 minutes after engine was shut off-40 psi
10 minutes after engine was shut off-32psi
Starts great when cold, but if you drive it somewhere, get out, come back 15 min later it cranks for a while, then when it starts runs very rich. O2 sensor was replaced 200 miles ago.
Also-Engine will idle at 600rpm, and then surge to 700/800.
What should the temperature be? Normally runs 220 deg.
Temp sounds a bit high, is that the temp you get while just cruising down the highway? 220 is typical in stop-and-go driving with the stock fan settings-they kick in around 225-228 degrees.
Good luck!
Ben
After a minute or so the flashes will slow from 2Hz to 1Hz as the ECM goes into closed loop mode. Once the ECM is in closed loop the flashes should have equal On/Off duration, indicating that the ECM is maintaining stoch A/F ratio. If not, the problem is either with the O2 sensor or the coolant temp switch in the front of the intake base under the TB.
A problem with this coolant temp sensor could account for hard warm starting as well as rich running if the ECM is always seeing too cold of a condition.
If idle is surging you might check for a vacuum leak (inlcuding a leaking EGR diaphram) or a dirty TB or IAC (right side of the TB).
1000RPM-35psi
engine off-44 psi
When you say its "rich" when it starts after a prolonged cranking, does it actually blow out black smoke? Or does it just smell rich? Have you checked the ignition system? Worn plugs will also cause a prolonged cranking, as will a weak coil. Coils will often act up when then underhood temperatures are high.
O2 has about 200
Air intake temp sensor (back by distributor) has 150 along with the coolant temp sensor, and EGR
Smells very rich.
So with that info, and whats in the thread above, we have narrowed it down to a weak coil or something with the MAF sensor correct?
