Invalid Response from PCM
Old Jun 7, 2005 | 09:40 AM
dan6712cc's Avatar
dan6712cc
Default Invalid Response from PCM
I just got my tune from PCMfor less and Im using CATS Winflash to read my PCM. I have a 94 which should be OBDI but it has an OBDII connector. When I try to read it gives me Invalid Response from PCM.
I have a laptop with a USB to serial connector which is connected to the ALDL connector. Im using the right comm port.. I dont know why its doing this.
Does anyone know what could be wrong?
Old Jun 7, 2005 | 12:16 PM
dan6712cc's Avatar
dan6712cc
Bryan from pcmforless just emailed me back and said it is probably the usb to serial adapter (good customer service he replied within 5 minutes). I'll give the real serial port a try and see what happens.
Old Jun 13, 2005 | 08:49 AM
Red Tornado's Avatar
Red Tornado
Dan, how did everything work out?
I agree, the service, knowledge and professionalism of pcmforless is excellent!
Old Jun 13, 2005 | 10:16 AM
dan6712cc's Avatar
dan6712cc
It was the USB to serial adapter that was the problem, I borrowed my brothers laptop with a serial connection and it read and programmed the pcm on the first try. I think the USB adapter will work if I figure out what the baud settings are.. there are a few parameters you can change with it.
Old Jun 13, 2005 | 10:30 AM
tjwong's Avatar
tjwong
If the USB adapter fails to work what will work are the PCMCIA cardbus serial adapters. These are pretty reasonable and you can find them by doing a search on google or yahoo.
To Invalid Response from PCM
