Bleeding clutch
Old Jun 8, 2005 | 07:55 AM
droptop86's Avatar
droptop86
Navigator
Default Bleeding clutch
Can anyone explain how to bleed the clutch hydraulic system. I did a search and came up empty. The car is a 86. Any help would be appreciated. Thanks, Mike
Old Jun 8, 2005 | 08:40 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Make sure master is full
Remove slave and hold at about 45* angle (bleeder screw at highest point)
Have someone depress clutch. While fully depressed, open bleeder screw, let air+fluid out then close bleeder. Then tell them to release the pedal.
Repeat 4 or 5 times till nothing but clean airless fluid comes out.
Old Jun 8, 2005 | 11:24 AM
Grace91's Avatar
Grace91
Here is a good thread on the subject.
http://forums.corvetteforum.com/sho...488&forum_id=48
Old Jun 9, 2005 | 10:57 AM
droptop86's Avatar
droptop86
Navigator
Thanks for the info! Mike
To Bleeding clutch
