Tps ??
Old Jun 10, 2005 | 07:33 PM
88sk's Avatar
88sk
Default Tps ??
what are the symptoms of a TPS goin out,at idle the rpm is goin up up&down about 400rpm's& when drivin the car feels like its kinda sputterin& holdin back.
Old Jun 10, 2005 | 08:15 PM
CFI-EFI's Avatar
CFI-EFI
Just check it it for proper operation with a volt meter.
RACE ON!!!
Old Jun 10, 2005 | 08:43 PM
sniperdiver37's Avatar
sniperdiver37
only a few things can go wrong with a TB.
1) TP sensor out of wack. should be just under .5 volts closed
2) leaking at the butterfly rod. Vacume leak.
3) you have alot of miles on it and it's dirty.
Get a repair manual at your parts store and check those things.
Old Jun 10, 2005 | 10:55 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/6E3-B%20Symptoms.pdf
Old Jun 10, 2005 | 11:19 PM
88sk's Avatar
88sk
am gettin a SES light,then when I check the codes the scantool says code 33& tps code is set too hi or low,cant get it below .58,now its on .62,when I drive for awhile the light comes on& codes are stored.
Old Jun 10, 2005 | 11:26 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/corvette86/Code%2033.pdf
http://members.shaw.ca/corvette86/Code%2021.pdf
http://members.shaw.ca/corvette86/Code%2022.pdf
Old Jun 11, 2005 | 04:34 PM
88sk's Avatar
88sk
Ok ,thanx guy's ,printed the info out& gonna see if I can find the problem.
To Tps ??
