GM's 383 stroker rods
Old Jun 13, 2005 | 12:49 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default GM's 383 stroker rods
GM made a custom stroker rod for their 383 crate engines.
Which use a standard bore but a 3.80 stroke, rather than a .030 overbore and a 3.75 stroke. Looks like they went after the 383 name.
So anyone using the GM stroker rods? Seems a nice way to get a 3.80 stroke w/o having to go to a reduced base circle camshaft.
Old Jun 13, 2005 | 12:54 PM
BrianCunningham
Just called a local dealer $486.39 for a set of 8
FD2BLK's Avatar
FD2BLK
I think this may be interesting information to Corvette Kid because he has a 3.8 crank and is building a motor with it.
Old Jun 13, 2005 | 02:09 PM
CFI-EFI's Avatar
CFI-EFI
So what is the center to center on those rods? A 3.75" or even a 3.80" stroke doesn't need a reduced base circle camshaft in any case.
RACE ON!!!
Old Jun 13, 2005 | 04:27 PM
BrianCunningham
5.7in
So your saying you can use stock rods, a stock base circle camshaft with a 3.8in stroke?
Old Jun 13, 2005 | 05:15 PM
tjwong's Avatar
tjwong
It is a decent rod for most street applications. Notice in the picture the top of the rod bolt and the rod has a chamfer, this is where the additional clearance for the cam is made. Normally when using a conventional GM style rod with bolts and nuts you have to grind this area for cam clearance.
When using stroker profiled rods such as the Lunati pro-mod, Lunati Billets, Oliver and other similar designs. There is no need to use a reduced base circle cam with a 3.75" stroke. Now if you go with a 3.875 stroke crank a small base circle cam maybe needed even with stroker profiled rods.
Old Jun 14, 2005 | 08:53 PM
RaiceC4's Avatar
RaiceC4
5th Gear
check out superenginebuilders.com They clearance Eagle rods for up to a 600 lift cam, standard base. I used these rods with an eagle crank and KB pistons and built big hp. Still have to clearance cylinder bottoms, but it is a very good setup and the whole balanced rotating assembly was around $900
To GM's 383 stroker rods
