nitrous
Old Jun 13, 2005 | 03:48 PM
BTTB's Avatar
BTTB
Default nitrous
any problem adding a dry 100 shot to a 383 stroker with 10.5 compression
Old Jun 13, 2005 | 03:53 PM
M.Clough's Avatar
M.Clough
no problem, but i would highly recomend using a wet system.It is a much safer system to use.On a dry system you are relying on the computer to add the fuel while on a wet system you are spaying fuel and the nitrous
Old Jun 13, 2005 | 04:01 PM
Pete K's Avatar
Pete K
Nope
Old Jun 13, 2005 | 05:31 PM
AZC4Guy's Avatar
AZC4Guy
I've been told a 100 shot can be a bit much for cast pistons.
Old Jun 13, 2005 | 05:40 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I have been running a 125 shot on my stock LT1 for 2 years without a problem. But I would also say to run a wet shot.
Old Jun 13, 2005 | 06:55 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I am guessing (hoping) that if he went through the bottom end to build a 383, they at least put hypereutectic pistons in it and those should handle 100 hp.
Old Jun 13, 2005 | 08:03 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
As others have stated, go wet. It's ok to run rich on N20, it may not run good rich, but ok. Run lean and it's goodbye pistons.
Old Jun 13, 2005 | 10:15 PM
BTTB's Avatar
BTTB
Default nitrous
Can you run a wet system with a super ram intake. My over all concern was 10.5 compression. Ive been told that 10.5 is to high for running nitrous. SRP pistons----dart pro 1 heads--- 219/225 comp cam.
Old Jun 13, 2005 | 10:53 PM
Pete K's Avatar
Pete K
I have the same basic combo and run a 150 shot (wet) been running it since 1995 and have not had a failure yet. I wore the rings out of my last 383. Took nine years of beating to do it though.
Old Jun 14, 2005 | 12:17 AM
jaymitchell01's Avatar
jaymitchell01
I have 11.5 on my ZR1 and I run a wet 100-shot, going to up it to 150-160 also, never had a problem, and don't plan to with the 150-160
Old Jun 14, 2005 | 07:42 AM
BTTB's Avatar
BTTB
pete----What are your quarter times-----what brand system do you have--tks
Old Jun 15, 2005 | 05:04 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
I am running a 383, super ram, 12:1, 150 shot wet.
I do run on 100 octane though.
Matt383
Old Jun 15, 2005 | 08:16 PM
Pete K's Avatar
Pete K
I have run a best of 10.97 on the spray. This was on a day when the car ran 12.40 na. The kit I use is an NOS 5151 wet system. I have been quite pleased with it. On a chassis dyno, the 150 shot gave an extra 147 hp and 202 ft lbs of torque at the wheels.
Old Jul 8, 2005 | 04:10 PM
1996man's Avatar
1996man
as far as shots and amount a stock block can take i was surprised when realized my buddy has a 94 camaro and has been running a 175 dry shot for almost 3 years now. i have ridden many times with him before and he uses it all the time. he has quite a few miles on his car as well. only mods are bolt on mods. i would say you could run a 100-150 shot carefully and not have a problem at all
Old Jul 8, 2005 | 05:10 PM
jburnett's Avatar
jburnett
Man, with forged slugs you can run a 300 shot if your rings are gapped properly. If they're gapped for naturally aspirated combination you can still run around a 200 shot before you start seeing ring flutter. However, as everyone else on here has pointed out; you NEED to run a wet system. Dry systems use increased fuel injector pressure (sometimes as much as 80-100 psi) to richen the mixture; the fuel injectors used in our vehicles (and most others) are pintle type and not made to handle that type of pressure. Plus it's inconsistent UNLESS you size the injectors for N2O and use stand-alone EFI system or burn a chip to compensate for it.
The biggest thing you're going to run into running a SR is the fact that the rear cylinders starve for fuel when running a single fogger nozzle or a plate system. The problem is the massive plenum. A true Fogger in the runners is the best way to go; but a plate or nozzle if you don't run over a 150 shot will be adequate as well.
-Jeb
Old Jul 8, 2005 | 05:35 PM
1996man's Avatar
1996man
do they make wet systems for LT1s? are they much more difficult to install?
Old Jul 11, 2005 | 04:37 PM
jburnett's Avatar
jburnett
You can either use a universal wet single nozzle setup like many company's sell or you can buy the NOS TPI system (p/n 05151) which is a plate system. They list it only for the TPI Vettes/F-bods, but it works on LT1's just as well and is the system I usually choose for LT1 applications.
-Jeb
Old Jul 13, 2005 | 08:23 AM
ASRoff's Avatar
ASRoff
Unlike turbos and superchargers. Compression ratios mean almost nothing to a nitrous system.
Check this out: rember while reading this that diesel's run as much as 20:1 compression
http://www.bankspower.com/Tech_nitrousoxide.cfm
Also read here
http://www.tuninglinx.com/html/nitro...tuning-17.html
Old Jul 13, 2005 | 11:46 AM
jburnett's Avatar
jburnett
Also read here
Yup...Nitrous LOVES compression... I have a 16.00:1 632" Big Chief motor that is a nitrous sniffing HOUND!!!
-Jeb
To nitrous
