being a zr-1 owner, with sixteen injectors to worry about, I've found most people go with injectors from RC engineering. I haven't replaced mine....yet, but will go with them when I do.
RC engineering will flow test and balance them prior to sending them out so you know they are gonna work. After reading the posts above about the problems with accell injectors, I would not touch them.
The RC engineering units are stainless so they will not rust. Hit thier website, I think you should consider them.
RC uses the Delphi Lucas injectors as we do. They machine and supply them with seals for use in the ZR1 intake. It takes many injectors to come up with a few matched sets. RC has made a commitment to stock injectors for the ZR1 which is a good thing as it is a very small niche market.
Racetronix stocks a wide array of Delphi/Lucas disc injectors for use in a L98 or LT1 Corvette.
