LT1 Build up need some help
Old Jun 14, 2005 | 12:11 PM
tvetta's Avatar
tvetta
Default LT1 Build up need some help
I am building an Lt1 with :
10:3 SRP Piston
LT4 Extreme Duty timing chain
LT4 Hot Cam Kit
LT1 heads with 2.00 intake and 1.55 Exhaust with port matched intake and some bowl cleanup
28lbs Bosch injectors
impala head gasket
Now my question, with the pistons and the Impala gaskets will my compression ratio be too high for premium gas?
Old Jun 14, 2005 | 03:52 PM
k99ja04's Avatar
k99ja04
Just curious but what brand head gasket are you using? I'm about to bolt on my shiny new Stage 3 LT4's from Precision Porting and am between the Felpro teflon coated or something from Cometic. I too was planning on using a thinner gasket. My understanding is it doesn't bumb compression significantly, maybe from 10.5 to 10.8, but it does improve quench height in the combustion chamber and thus the efficiency of the burn.
Old Jun 14, 2005 | 04:10 PM
FD2BLK's Avatar
FD2BLK
What dish is the psiton? did SRP say it would be 10.3:1 withthe LT1 heads? If so you are fine I think the stock CR is 10.7:1 and i have seen many LT1s in the 11.5-12.5 range with no problems.
Old Jun 14, 2005 | 04:45 PM
tvetta's Avatar
tvetta
I am using the GM gaskets.
The pistons are SRP 138081 and the compression ratio is calculated using zero deck clearance with .040 gasket and 64cc heads on a small block
Old Jun 14, 2005 | 04:55 PM
STL94LT1's Avatar
STL94LT1
You know that LT1 heads have 54-55cc combustion chambers?
Old Jun 14, 2005 | 05:02 PM
tvetta's Avatar
tvetta
I really don't know very much about engines and was throwing the questions out there.
What does that do for me the LT1 are 50-55cc vs 64cc?
Old Jun 14, 2005 | 05:13 PM
STL94LT1's Avatar
STL94LT1
Pretty sure it will raise your compression by about a point.
Old Jun 14, 2005 | 06:43 PM
Morley's Avatar
Morley
Using the info you give and 55cc heads your compression would be 12.29:1 Thats with a gasket with a .040" compressed thickness, that's getting in dangerous territory for detonation.
Switch to a gasket with a .060" compressed thickness and your compression will drop to 11.58:1, a little more manageable on preimum gas.
Worst case with a 50cc head and .040" gasket you are looking at 13.29:1 CR (better run race gas)
50cc head and .060" gasket is 12.42:1
Old Jun 14, 2005 | 07:40 PM
FD2BLK's Avatar
FD2BLK
Using the static CRs that Morley gave and knowing you are going with a fairly mild cam i would try to stay below 12:1 if possible. If you had chose a more agresive cam you could go a little higher but as long as you end up below 12:1 withg the hot cam your dynamic should be fine. If it where me I would use the .060 head gasket and scrap the impalla gaskets for another project with your set up.
Old Jun 14, 2005 | 08:18 PM
tjwong's Avatar
tjwong
10:3 SRP Piston
LT4 Hot Cam Kit
impala head gasket
First of all what displacement are you going to run? If its a 383, then a flat top with -5cc for valve releifs with stock 55cc chambers, and a .039 compressed gasket thickness would give you around 12.5 to 12.7:1 compression.
If you are talking about a stock 350 displacement + a .030 overbore for the new pistons then using a stock head, figure zero deck meaning that the pistons are even with the top of the block deck. With that combo, a 55cc head, .039 head gasket you should end up with around 10.5 to 10.8:1 CR. Stock LT4's were running around 10.5:1 using a 54cc head and a .041 gasket. Their pistons were slightly taller in dome height but they were still effectively a flat top with eye brows. Assuming the new SRP pistons have valve releifs they are typically -5cc in volume.
LTx engines with their efficient reverse cooling are good to 11:1 on pump gas. I am presently in the process of building a 383 with a -11cc dished piston and 55cc heads to give me a final compression of 11:1, this is also calculated with the pistons in the "hole" .005 to allow for piston rock as these will be the 2618 alloy pistons which require a little more clearance.
Old Jun 14, 2005 | 09:42 PM
FD2BLK's Avatar
FD2BLK
Tom I come up with a bit diferent CR for the -5cc dish FT (Finaly looked up the PN) did I screw somthing up? It does corilate withthe SRP web sites
Again confirm this with SRP but I would stick withthe stock .060 gaskets and sell the Impalla ones
Cylinder head Volume (CC) = 55.00
Piston Top Volume (CC) = -5.00
Cylinder Bore (Inches) = 4.030
Cylinder Stroke (Inches) = 3.48
Deck Height (Inches) = 0.030
Head Gasket Thickness (Inches) = 0.040
Computation Results:
Computed Compression Ratio is 12.3 to 1
Input Parameters Are the Following:
Head Gasket Thickness (Inches) = 0.060
Computed Compression Ratio is 11.6 to 1
SRP web site states 11.1 with 58 cc heads 3.48 strole and 4.030 bore
http://www.jepistons.com/pdf/2005-srp.pdf#search='SRP%20pistons%20compress ion%20ratio'
My calculator comes up with
Cylinder head Volume (CC) = 58.00
Computed Compression Ratio is 11.1 to 1
Old Jun 14, 2005 | 11:15 PM
tvetta's Avatar
tvetta
I am glad I started this thread. The machine shop hasn't started assembly yet! This forum is great and thank all of you for your input.
Old Jun 15, 2005 | 12:39 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Will you be running zero deck? If so, a .040" gasket will be the minimum you should use. A .050" would be safer.
Old Jun 15, 2005 | 01:13 PM
tvetta's Avatar
tvetta
Guys, I can't begin to thank all of you for your help!
I spoke to my Machine Shop and he said that was an overlook on his part. Everything is cool, going with the stock replacement compression piston.
Regards,
Tony
Old Jun 15, 2005 | 09:40 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Me too.... I just learned something.. Now I need to find the calculator to figure tis stuff out on myown
To LT1 Build up need some help
