Any experiences with Hypertech Street Runner?
Old Jun 18, 2005 | 11:26 PM
LLL746's Avatar
LLL746
Default Any experiences with Hypertech Street Runner?
I have an 86 coupe with 4+3 transmission, K&N air filter with open faceplate on it, otherwisw pretty stock. OD works fine. On Interstate trips I get 22-23 mpg by calculation (the digital dash agrees very closely with those mpg results, but I would like to get better mpg on the open road.
The Hyperchip Street Runner sounds/looks like a nice insert for me, but the hp chart on the Hyperchip website doesn't look like it makes much difference below 3500 rpms. I am turning 2000 rpms at 72 mph on the Interstate, and I'm rarely above 3500 rpms, so I wonder:
Would the Street Runner chip make any difference for me in mpg or general driving?
I did a search for Hyperchip, and only hit 4 results. In one reply I read a comment about 22-23 mpg might mean an O2 sensor is faulty. Does anybody have experence with this?
Thanks for the feedback.
Old Jun 18, 2005 | 11:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I was running higher fuel pressure with my AFPR, an agressive TPS setup, base timing bumped to 8deg BTDC and a 160deg T-stat & fan switch, I tried a Hyper Tech chip and saw absolutely no difference at the strip nor on the highway.
I don't think that chip will add anything to performance nor to gas mileage.
Have you checked mileage averaged over a few miles of flat highway with cruize set?? These are the conditions under which I feel that I can get reliable readings for comparison with each mod I make.
Old Jun 19, 2005 | 12:18 AM
vettenut85's Avatar
vettenut85
you should be getting closer to 28+ mpg on the highway.it may be time for a full tuneup if that has not ben done in a long time,also dont forget to change the fuel filter and i would be suspecious about the 02 sensor,they are not that expensive to replace on your year.
Old Jun 19, 2005 | 01:14 AM
vader86's Avatar
vader86
Chip is useless in terms of mpg and HP.
First thing to do is give it a full tune-up, plugs/wires/cap/rotor, then O2 sensor, and then you may need to replace injectors because if one is leaking it'll kill your mileage.
Old Jun 19, 2005 | 02:33 AM
johnnyevans's Avatar
johnnyevans
Amen on the good tune-up. I did try one of those chips a friend had. It did make a difference on my gas mileage ... it went down.
Old Jun 19, 2005 | 04:32 AM
cplonner's Avatar
cplonner
if you want to buy the chip, dont. ill take your 200 bucks, and your car will still have the same performance gain
Old Jun 19, 2005 | 05:47 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I get 25 mpg highway.. the cold air intake got me a consistent 2mpg increase.
To Any experiences with Hypertech Street Runner?
