LUG NUT torque
Old Jun 22, 2005 | 12:56 PM
Carl Johansson's Avatar
Carl Johansson
Default LUG NUT torque
Anyone know the recomended torque for lugnuts (86 coupe) (away from my books right now - sorry!)
Carl Johansson
Old Jun 22, 2005 | 12:57 PM
Bob CTS's Avatar
Bob CTS
I 'think' 100 ft/lbs. then retorque after 25 miles.
Old Jun 22, 2005 | 01:16 PM
boulderlt4's Avatar
boulderlt4
It is 100 on my '96.
Old Jun 22, 2005 | 01:37 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Roger that.
Larry
code5coupe
Old Jun 22, 2005 | 02:16 PM
Steel Blue 91's Avatar
Steel Blue 91
Ditto on my 91.
Old Jun 22, 2005 | 03:58 PM
pwrful c4's Avatar
pwrful c4
On my 94 its a 100 but on earlyer models I thought I heard its 80.
Old Jun 22, 2005 | 04:50 PM
rws.1's Avatar
rws.1
100 on my "88
Nathan Plemons's Avatar
Nathan Plemons
More torque than a Honda makes
Old Jun 22, 2005 | 04:59 PM
ALLT4's Avatar
ALLT4
Just get an impact gun with about 180psi and let that baby smack it for about five minutes like garages do.
I go 80 myself, 100 feels like it's sinking the nut way into the aluminum sawblabes. If the wheels falls off at 80 it's going to fall off at 100, JMHO
Old Jun 22, 2005 | 05:49 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
With my "clicker" type torque wrench, I was surprised how loose 100 ft.lbs is. When i'd do it by hand, i'd go significantly tighter than 100 just using feel and how tight I thought it should be.
Old Jun 22, 2005 | 06:02 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
100 ft/lbs - It's based on the lug diameter and thread pitch.
I keep the threads lightly lubed with wheel bearing grease. Helps to ensure the torque consistency and prevents thread galling.
Old Jun 22, 2005 | 06:24 PM
c4cruiser's Avatar
c4cruiser
I use a very light coat of anti-sieze on the lug threads. I had read that depending on the fastener, a grease or oil coating can change the torque value.
I tighten my lugs in three steps to 100 ft-lbs: 50, then 70 then 100 ft-lbs.
Old Jun 22, 2005 | 06:42 PM
dndrsn's Avatar
dndrsn
I have never put a torque wrench on a lug nut. I have not had a wheel fall off yet. I guess I'm just lucky.
Old Jun 22, 2005 | 07:48 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old Jun 22, 2005 | 09:15 PM
c4cruiser's Avatar
c4cruiser
Torquing the lugs evenly helps to keep rotors from warping. If one or two lugs are way too tight, the rotors can warp if they go thru cycles of extreme heat and cooldown.
Old Jun 22, 2005 | 09:49 PM
Carl Johansson
Default thanks guys
I guess I'll use myu clicker wrench and 3 step em to 100 lbs. Thanks
Old Jun 22, 2005 | 10:52 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Pretty damn tight.
You guys actually use a torque wrench on em?
To LUG NUT torque
Old Jun 22, 2005 | 11:22 PM
tonymax2's Avatar
tonymax2
I would advise checking the GM manual to see if that 100 ft-lb spec was with lubricated parts or "dry". The difference can be very great and could result in overtighting.
Old Jun 22, 2005 | 11:54 PM
86C4EVER's Avatar
86C4EVER
Originally Posted by CentralCoaster
Pretty damn tight.
On the Vette, always.
100lbs on wheels,
80lbs for the spare.
Fred
Old Jun 23, 2005 | 01:08 AM
CentralCoaster
I guess I'm the abnormal one then. You guys probably don't offroad in your vettes either. :o
