Drag race Alignment specs.
Old Jun 24, 2005 | 12:11 AM
red L98's Avatar
red L98
Default Drag race Alignment specs.
Hey guys I got my car done this week and I need to get it aligned badly. any specs would help I drag race the car .
thanks
Old Jun 24, 2005 | 12:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you drive it on the street too, just get a stock alignment.
If you trailer it there, reduce toe-in.
Old Jun 24, 2005 | 01:04 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Zero toe front and rear.
I seem to be getting toe out on squat though. Maybe a little toe in back to compensate isn't such a bad thing..
Old Jun 24, 2005 | 10:05 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I had mine set to stock setting, however I then toe the tires so at launch you have the entire tire's footprint on the road. Check out my sig picture, the tires on the launch are flat and the car is working well.
Old Jun 24, 2005 | 11:20 AM
mike 1985's Avatar
mike 1985
I think VTB web site or something similar to that has alignment spec's. I went with the advanced street spec's and i'm happy with it at the track and on the street.
Mike
Old Jun 24, 2005 | 06:03 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Do it right and change the rear end fluid too.
Here are the spect for everything.
http://www.vbandp.com/instructions/h...ruct/align.htm
Old Jun 24, 2005 | 11:52 PM
red L98's Avatar
red L98
thanks guys , i took the car for a spin the motor , trans and rear feel very good , but the car is all over the road and the rear tires are in more .
thanks
Old Jun 25, 2005 | 07:32 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
My car feels HORRIBLE when I have the slicks on it and skinnies up front, if there is ANY difference in air pressure between the back two wheels! Are you running street tires or do you have slicks on it. That may be why it feels all over the place.
With mine, it practically MAKES me change lanes on the road if I am cruising around and gun it with the tires as described above.
As far as with the street tires, it just spins them.
Old Jun 25, 2005 | 08:34 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I have heard that some of the stock eliminator guys will get hooked up with an alignment shop who will let them be in the drivers seat and jack the front end up an inch or so while it is being aligned. The premise is that the car's alignment will be perfect how the car will be going down the track. I never did it in all the years I bracket raced because I still drove the car on the street some and figured that wouldn't be ideal for street driving. I did think it sounded like a decent idea for an all out race car.
Those stock eliminator guys are all abou the craziest little thing to pick up ET since they can do so little to their car - it's knowing these guys where I learned how to set up a leaf spring, small tire car to 60'.
To Drag race Alignment specs.
