stupid hood light question
Old Jun 24, 2005 | 07:14 PM
95polo's Avatar
95polo
Default stupid hood light question
Tomorrow I will be attending my first car show. I am not crazy about it but the place where my wife works is sponsering it. I know this is a stupid question but at a car show when you have the hood up showing all the time consuming detail you did to the engine compartment, how do you keep the the battery from draining? Do you pull the fuse to keep the hood lights from staying on or what? The show lasts for 3 hours I know my battery will go dead but I want to show off all the work.
Old Jun 24, 2005 | 07:22 PM
F1Fan's Avatar
F1Fan
I'd definately pull it. I take the fuse out at cruise-ins when I have the hood up for any extended period. If it's dark out at the show, it really won't make enough light to make much of a difference anyway, at least mine don't.
(Got a '95 polo green myself )
Old Jun 24, 2005 | 09:00 PM
kize's Avatar
kize
I put a hood switch in. You can wire your own cutoff switch. Or if you are electronically challenged, you can purchase a kit from MAD, CORVETTE CENTRAL, etc.
Old Jun 24, 2005 | 09:15 PM
jwt1603's Avatar
jwt1603
I do it the cheap way, just unplug the lights. Follow the wire down form each light and there are plugs that you just release and then have no battery drain. Just pry the retaining clip up a little and gently pull on both pieces and the plug will separate.
When you drive in the rain and / or wash it you should plug them back in to prevent corrosion of the contacts.
Old Jun 24, 2005 | 10:01 PM
jabez's Avatar
jabez
No need to pull fuse just unplug the wires to the lights. Takes 10 secs.
Old Jun 24, 2005 | 10:08 PM
rws.1's Avatar
rws.1
I agree unplug the two connectors one each side forward of the wheel well. If fact, mine are permanently disconnected.
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since I drag race my '88 I can't be bothered with the fuse every time I open the hood so I installed the harness assembly from MAM.
It just plugs into the power source and into each light harness on either side. There is a toggle switch that is hidden for easy on/off of the lights. Of course it's also handy when working under the hood on some R&R project or just some engine compartment detailing.
Old Jun 24, 2005 | 11:08 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I pulled my fuse 2 years ago...I drag race a lot too...in front of the drivers side front wheel you will see the connector...pop it apart and remove the fuse...plug it back together if you want to leave the fuse out or leave it apart and put the fuse back in after the show ...
Old Jun 25, 2005 | 10:13 AM
95polo's Avatar
95polo
Thanks for everyones help!
Old Jun 25, 2005 | 10:53 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I made up dummy plugs for both sides of the connectors to keep them nice and clean in case I should ever need the lights.
To stupid hood light question
