Take a look at your pushrods. With the 1.6 ratio rockers, the pushrod may be hitting the cylinder head at the pushrod hole because it is now closer to the rocker stud. Check for wear marks on the pushrod and around the pushrod hole.
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I inspected the pushrods pretty good during the cam swap and they all seemed to look great. Lifters looked good too.
Although as of my order today, I am replacing both.
I've used the stethiscope on them too but the tic only starts happening at 2K rpm and up. Its not present at idle. They all sound the same at idle. I can't run the motor with the valve covers off at any speed above idle due to the oil pump starts really throwing it out!!
Todd said if it was just a loose rocker, you should be able to hear it at idle. Sounds like something else is going on. Did you roll the pushrods on a piece of glass or something to see if they were all straight? Kind of a moot point now that you have new pushrods coming in.
Victor and I compared ticks the other day. His sewing machine is definitely louder than mine. My LT4 has what I might call a muted, soft tick, whereas Victor's LT4/1 has a very sharp ticking. Would you agree Victor?
Lemme know if you want to borrow my HF stethoscope.
Generally, the more aggressive the cam/rocker ratio is, the more valvetrain noise. Hope none of your springs are broken; they can run OK and quiet at idle and make the noise you are talking about. Don't want to get you worried but it is a possibility albeit remote.
My stock springs only provided ~86lbs on the seat and I shimmed my Comp Cams springs to ~110lbs to assure valve control with my ProMagnums.
Since your problem starts at elevated RPM it may well be a matter of spring load.
While I don't disagree with any of the above, it would take one nasty cam, coupled with some pretty mis-matched springs, set to a really wrong installed height, to start making noise at 2000 rpms.
I really don't think the installed height of the springs is the problem, here. They may be set wrong, but I doubt they are the cause of the noise.
St. Jude Donor '03
zrated
w/ that.
and thanks for the good responces, guys. I'll have plenty to do when my new parts come in.
